killerfrogs
Amarillo, TX, USA |
Registered on 4/11/2016 |
1 post |
Posted:4/11/2016 20:24 |
I just purchased a 89 F-150 with a 302, 2 wheel drive, auto. The window sticker says the oil was recently changed, but the dipstick shows it over full. I changed the oil and added 6 quarts and the dipstick is overfull again. I'm thinking I have the wrong dipstick. The one I have is E5TE6750-CA which is 31 inches long.
Thanks |
Bear79
Stephenville, TX, USA |
Registered on 7/5/2016 |
12 posts |
Posted:7/6/2016 13:08 |
The 302 oil capacity was 5 quarts with the FL1a. The 351w was 6. The next oil change add 5 quarts, start the engine and recheck it after it set not running in 5-10 minutes. That will tell you if it is correct. I do not think that the dip stick is not the issue. |
