rojo82
Atlanta, GA, USA |
Registered on 6/27/2011 |
2 posts |
Posted:6/27/2011 16:38 |
I have a 5.4L V-8 lout of an 2004 ford F250 Super Duty with 60,000 miles on it and i want to put it in a 2001 Crown Victoria. Will this task be difficult? |
aanbae
jakarta, XX, Other |
Registered on 10/30/2010 |
6 posts |
Posted:8/18/2011 20:25 |
Yes... |
vicky2362
Los Angeles, CA, USA |
Registered on 8/26/2011 |
2 posts |
Posted:8/26/2011 16:58 |
I need Help I have a 1995 Crown Vic. and I cant take the tire off after removing the lug nuts and the axle nut to replace the Disc Brakes can anyone help |
kudel
idaho, ID, USA |
Registered on 8/28/2011 |
1 post |
ericsiswanto
Makassar, XX, Other |
Registered on 9/2/2011 |
3 posts |
Bobbyseas
Kalona, IA, USA |
Registered on 9/19/2011 |
1 post |
Posted:9/19/2011 13:25 |
vicky2362
I had the exact problem not even a month ago! I did everything I could think of which included beating on it for hours (tire and rim are both shot now) to spraying multiple cans of WD-40. Used a torch to heat it all up. Even went so far as to loosen lugs till end of the threads and drive around! All I can tell you is to keep at it (took me a week and a half) and eventually it will come off OH before I forget you should expect to need a new tire, rim,and rotors!
hope it helps |
