2005 crown vic cooling fan problems
Thread Statistics:     Users to Post: 4   |   Total Posts: 12   |   Total Views: 2867
ranchero74
• Pelzer, SC, USA
• Registered on 10/14/2014
• 7 posts
Posted:10/14/2014 12:01
I have a 2005 crown vic cooling fan will not come on, overheats at stop light.
I have jumped the fan straight to the battery, and it runs. I have replaced the temp. sensor, checked the fuses, even got a new fan assembly and tried it, didn' work. Does anyone have any ideas?
curemode2002
• Lehi, UT, USA
• Registered on 3/8/2012
• 147 posts
1
Posted:10/14/2014 12:09
So the Vics have a Radiator Fan Relay as well do you know if this has been checked? Looking at all the other information I did not see it mentioned.
ranchero74
• Pelzer, SC, USA
• 7 posts
Posted:10/14/2014 12:21
I swapped relays in the box behind the battery, could there be another one that i missed?
ranchero74
• Pelzer, SC, USA
• 7 posts
Posted:10/14/2014 12:23
Also, I tried the new fan with engine running and air cond. on, every think I have read said it should be running with air on.
curemode2002
• Lehi, UT, USA
• 147 posts
1
Not that I have seen in the wiring diagram you may want to try testing the contacts the relay plugs in to and see if you have any shorts.
ranchero74
• Pelzer, SC, USA
• 7 posts
Posted:10/14/2014 12:29
Can you use a test light to check it, it is all I have.
curemode2002
• Lehi, UT, USA
• 147 posts
1
Posted:10/14/2014 14:01
For some of the connections yes but for the ground connections you would really need a multi-meter. Do you have a Harborfreight near you? If you do they have an awesome little pocket multi-meter for under $10.
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4
Posted:10/14/2014 14:25
there is a fan control module on the fan assembly itself, it could have gone bad.
ranchero74
• Pelzer, SC, USA
• 7 posts
Posted:10/14/2014 15:39
I have replaced the fan assembly, replaced all relays, and replaced the temp. sensor.
Yes, we have a harbor freight near us, and I will be there in the moring. I am thinking something is not sending a signal to power the fan. Just don't know enough about it to figure it out.
plstktnkr2
• Reisterstown, MD, USA
• Registered on 7/27/2011
• 13 posts
2
Posted:10/14/2014 19:24
did you run 12v directly to the fan to see if motor was good?
1966 Lincoln 'vert
1985 Lincoln Hearse
1983 Mustang 'Vert
