66 Fairlane 500 W/ disc brakes
Thread Statistics:     Users to Post: 2   |   Total Posts: 9   |   Total Views: 1403
John trimpi
• El Cajon, CA, USA
• Registered on 2/18/2004
• 20 posts
Posted:2/25/2004 14:45
I just purchased a 66 Fairlane 500 Hardtop for my son. Car has a 289 2V W C4 trans. This car has manual front disc brakes. I haven't looked at the production date on the door yet. Could this car have come from the factory wit disc?
Just noticed I should have posted in the vintage forum. NEWBEE'S
edited 2/25/2004 15:02
D.B. Roberts
• Renton, WA, USA
• Registered on 11/15/2003
• 56 posts
2
Posted:2/25/2004 19:37
Hi John,
Welcome to the SuperFord forums...
It is possible that your 66 may have had factory disc brakes.
I believe that they were a special order option in 66.
It's also possible that the brakes may have been upgraded at some point.
If it has a factory setup, it would be using Kelsey-Hayes 4 piston calipers
and the hat/hub section of the rotor would be vented.
If the brakes are different than this they may be from a later model Fairlane or a Granada/Monarch.(A very popular upgrade choice)
Is your 66 a GT/GTA?
'67 Ranchero 500 - 351C-4V/AOD - Daily Driver
'69 Titan Mk.5 Formula Ford
John trimpi
• El Cajon, CA, USA
• 20 posts
Posted:2/26/2004 16:46
Thanks for the tips D.B. I'll check out the design and get back to you.
No unfortunatly it's just a 500 Hardtop.
edited 2/26/2004 17:14
D.B. Roberts
• Renton, WA, USA
• 56 posts
2
Posted:2/26/2004 18:58
I thought from your initial post that was the case, but wanted to make sure...
On the 67 GT/GTAs the front disc brakes were standard equipment. I'm not sure that the 66's were the same. On a standard 500 I'm fairly sure they would have to be a special order. Not necessarily factory installed as many dealerships in the 60's did option installs in house.
It is possible to contact Ford Motor Company's Customer Relationship Center and request they send you the "original specifications and optional equipment" for your vehicle at the time of manufacture.
I did the request for my Ranchero and got a letter back in a couple of weeks that gave me a breakdown of the VIN, the production date, and the applicable options list.
This is a free service and provides a solid starting point as to what the car had originally.
In the United States:
Ford Customer Relationship Center
P.O. Box 6248
Dearborn, MI 48126
Phone: 800-392-3673
800-232-5952 (TDD for the Hearing Impaired)
Hours of Operation:
8:00 a.m. - 8:00 p.m. ET. (Monday-Friday)
9:00 a.m. - 5:30 p.m. ET. (Saturday)
edited 2/26/2004 19:00
John trimpi
• El Cajon, CA, USA
• 20 posts
Posted:2/27/2004 09:34
Thanks D.B. You have some great info. here. I will write Ford for the specs.
Turns out the disk and caliper arn't stock according to your info. provided. The rotor is solid (no vents) and the caliper is a single piston. The car has not been driven for awhile (not sure how long). We will be pulling rotors, pads, bearings etc. for inspection in the near future and hopefully be able to ID them at that point. I will post some pictures as we progress.
Thanks again and keep the info. flowing.
John trimpi
• El Cajon, CA, USA
• 20 posts
Posted:3/11/2004 12:36
Thanks DB for the build sheet info. Finally got one one order today.
John trimpi
• El Cajon, CA, USA
• 20 posts
Posted:3/29/2004 15:34
Turns out these disc brakes are from a 79 Granada. At least that is what is stamped on them. Brakes all check out and look like new. Someone had done a fresh brake job.
D.B. I also didn't have much luck with the build sheet. Turns out the drivers door has been replaced and the tag does not match the car and the vin. on the reg. doesn't work either. Oh well it's still a great project car. We must be lacking something in the numbers. Both door and title break it down to a 66' hardtop built in Kansas with a 289 2V. Only difference is the last 6 digits. Not sure what Ford's problem is?
John
D.B. Roberts
• Renton, WA, USA
• 56 posts
2
Posted:3/30/2004 00:04
John, to verify the VIN on the 66 look on the top of the structure the radiator mounts to. On the driver's side under the rubber hood seal... The VIN should be stamped into the top rail.
I don't know why Ford's customer relations group should have a problem giving you info on your 66, unless the database doesn't go back past 67. There is still some information that can be determined just by decoding the VIN...
John trimpi
• El Cajon, CA, USA
• 20 posts
Posted:3/30/2004 12:02
Thanks for the info. D.B. I will check the locations and see what I can come up with. Ford did state that that year was hard to do.
John
