Vibration Problem
Thread Statistics:     Users to Post: 6   |   Total Posts: 15   |   Total Views: 4418
Brian Olson
• Birmingham, AL, USA
• Registered on 3/12/2003
• 11 posts
Posted:3/14/2003 22:43
I just bought a 1993 Bronco XLT with the 351 and E40D, truck has 110,000 miles, and has never been wrecked or lifted. Everything appears to be stock, but there is a harsh/severe vibration, clearly from the rear of the vehicle, which I have not solved with new U-Joints in the rear drive shaft. Always there under light load, but rears it's ugly head under heavy load from 45-55mph, and under constant load from 70-80mph,predominantly under load and acceleration up a hill. Already tried to shim the rear end above and beyond what looks like 7 degree factory wedges in place, to eliminate pinion angle problems, helped slightly at 20-45mph speeds , but no effect at higher speeds. Anyone with any experience with an apparently factory Bronco, please help !!!
Don Stith
• New Orleans, LA, USA
• Registered on 2/5/2003
• 42 posts
1
Posted:3/15/2003 07:57
I had a vibration in my 93 same set up. The vibration wasn't there while it was in third or overdrive but occured only when the tranny was shifting between the two gears. Torque converter was the culprit. Hope this helps. Don
Brian Olson
• 11 posts
Posted:3/15/2003 20:21
I appreciate the info, what exactly is the problem with the torque converter, and what are the causes ? Milage, design problem, did you go back with a converter from the dealership, aftermarket ?
massbronco
• somewhere in mass, MA, USA
• Registered on 8/5/2002
• 12 posts
5
Posted:3/16/2003 18:19
i had same vibration from the rear. i replaced the u-joints on the double carden yoke that seemed to be the problem in my case
just my 2 cents
good luck
Brian Olson
• 11 posts
Posted:3/17/2003 00:34
Changed all three ujoints in rear drive shaft this weekend, no results .......have heard that the ring gear bearin may wear and give vibration, any experience out there with this ?
massbronco
• 12 posts
5
Posted:3/23/2003 17:46
did you check the double carden ball assembly for wear? if it is worn you may get some vibration.
johnb
Jason Rich
• Big Stone Gap, VA, USA
• Registered on 4/4/2002
• 30 posts
2
1
4
Posted:3/24/2003 16:57
Just a but of more advice. Check the rear driveline itself, It may be bent or warped causing vibrations at high speeds. Hope this helps.
massbronco
• 12 posts
5
Posted:3/25/2003 23:05
hey jason
that happened to my 80 bronco don't know why i didn't think of that before.
my spring perches were bent 1/4" into axle tube from pullng hole shots on pavement with 36" mudders. had a buddy weld some beads on til i could grind it down level put block back on and i was set.
john
Brian Olson
• 11 posts
Posted:3/26/2003 04:07
Hey guys, I changed the trans/torque converter fluid and filter and the vibration is 95% gone! Wasnt all that dirty, but did it ........now only hear a rhythmic slight roar when trans is under load at freeway speeds up an incline. Probably indicative of trans rebuild or new torgue converter as suggested in my near future, but She's gonna have to run for awhile! Appreciate all the help !
BroncoHound
• Registered on 4/29/2003
• 34 posts
2
Posted:4/30/2003 21:11
Hey Brian,
Where in Bham are ya? I live here to and have an 86 full size doing the same thing.
The guy I bought it from said that I need to change out some valve or something? I cant remember. anyways if anyone knows what valve he was talking about let me know. But Brian email me and maybe we can hook up and good mudding one weekend.
[email protected]
[email protected]
edited 4/30/2003 21:13
Vibration Problem
