need an OBDII Diagnostics Tool
Thread Statistics:     Users to Post: 5   |   Total Posts: 5   |   Total Views: 3395
dianahhh
• new york, KY, USA
• Registered on 11/18/2013
• 9 posts
Posted:3/14/2014 19:04
My check engine light is on and I'm considering purchasing a diagnostics tool. Does anyone have any recommendations? I use a Mac, so I need one that explains the codes on the device itself. I also don't need the Rolls Royce of devices.
thanks.
1
Posted:3/15/2014 06:36
Most auto parts houses like Autozone and Advanced Auto will scan it for you for FREE, but if you want one for yourself either go cheap with a simple reader or go PRO with a good one. Be sure you get one that will reset / clear the code, or you will be running around with the code flashing the engine light after the problem is fixed.
A scanner reader can get simply the code, and that is all. Or the scanner reader can get the codes and other information like coolant temps, rpm , MPH, and things like this. The more expensive will get the codes, explain what system the code relates to, a breakdown of how to troubleshoot, plus all other information the computer has stored. PLUS the reset / clearing of the code. The Higher the price, the more information it will pull from the computer.
Here are 3 links to the OBD Scanners. Once you get the code, you can Google it online REGARDLESS what type of computer you have. (I run Linux AntiX.)
http://www.harborfreight.com/can-obdii-code-reader-with-multilingual-menu-98568.html#.UyRUVvldUrU
http://www.oreillyauto.com/site/c/search/Code+Readers!s!Scanners/N0664/C0103.oap
http://www.autozone.com/autozone/accessories/Tools-Garage-and-Equipment/Code-Reader/_/N-25iq
My personal preference is the Actron CP9575. ( http://www.autozone.com/autozone/accessories/Actron-OBD-II-and-CAN-Professional-trilingual-scan-tool/_/N-25iq?itemIdentifier=98817&_requestid=4460608 ) It is just short of the type of scanner that explains what the code means. It gives you the codes and what the code relates to.
If you do maintenance on several vehicles, get a good scanner reader. If you don't do much maintenance on your own, get a cheap one. You will need to Google the code and then start reading the results. Be sure to check the forums about the code too. Although the code may be related to one system or systems DOES NOT mean that is the problem.
I once had a code for a bad O2 Sensor.
Cost = $ 95 USD. OUCH
Google search = vacuum leak.
Replaced vacuum line = $1.50
Time spent = 2 1/2 hours
Problem fixed and cleared code.
edited 3/15/2014 06:49
Robert9
• linui, IA, Uganda
• Registered on 4/15/2014
Posted:4/15/2014 18:31
OBD-II tools are hand held devices that link to your car's on board diagnostics through the data port (under the hood or under the dash). They provide a wealth of information, more than enough for the average DIY mechanic.
carobd2shop.com
rocks69
• Tampa, FL, USA
• Registered on 5/5/2014
• 9 posts
Posted:5/8/2014 17:59
Do you really want to purchase one? I find a good and cheap one at autozone I just forget the brand or as them w/c one they would recommend.
Tonyback
• LA, CA, USA
• Registered on 9/23/2014
• 8 posts
Posted:9/23/2014 23:09
Launch X431 diagun 3 works on both gasoline and diesel vehicles, powerful diagnosis...
