Ozzie
Kansas City Mo., MO, USA |
Registered on 5/20/2005 |
15 posts |
Posted:6/22/2005 22:54 |
Does my 2001 Ex have a setting for using driving lights, as most newer vehicles have? I would like to have them for safety.
Also, is there a setting to lock the doors automatically when driving?
Thanks, guys.
Oz. |
Bigjakes12
Phoenix, AZ, USA |
Registered on 4/19/2005 |
29 posts |
1 |
Posted:6/23/2005 01:21 |
Oz,
Here's the rundown. I think its been posted before, but what the heck. Good luck.
Keith
How To Disable AutoLocks
Note: Manual transmission vehicles have this feature disabled at the factory. This procedure applies to most newer Ford vehicles, not just Ford trucks.
The enable/disable mode allows the autolock feature to be turned off and on. On manual transmission vehicles, when replacing the remote anti-theft personality (RAP) module, the autolock feature must be turned off by using the enable/disable mode.
The enable/disable mode is entered when the following series of steps is performed:
1. Confirm that the perimeter alarm is disarmed.
2. Close all doors.
3. Confirm that the ignition switch is in the OFF position.
Note: Steps 4 through 8 must be performed within 30 seconds.
4. Turn the ignition switch from OFF to RUN.
5. Press the power door lock UNLOCK button three times.
6. Turn the ignition switch from RUN to OFF.
7. Press the power door lock UNLOCK button three times.
8. Turn the ignition switch from OFF to RUN.
9. Verify that the RAP module chirps the horn. This indicates that the RAP module is now in the enable/disable mode and ready to accept program changes.
10. Press the power door lock UNLOCK button one time to command the RAP module to toggle the autolock/relock feature ON or OFF.
11. Press the power door lock LOCK button once to enter the command.
12. Verify that the vehicle horn chirps one time to signal the RAP module confirmation of the command. There should only be one chirp indicating that the autolock/relock feature has been disabled. If one chirp is heard, followed by a longer honk, the autolock/relock feature has just been enabled. Return to step 10.
13. Turn the ignition switch to the OFF position to exit the enable/disable mode.
14. Verify that the RAP module chirps the horn once to indicate that a feature has been changed.
The autolock and the appropriate alarm configuration are turned on at the factory on vehicles with automatic transmissions. Vehicles with manual transmissions have the autolock turned off at the factory. The RAP module returns to the prior setting any time battery power is interrupted.
DFW, TX, USA |
Registered on 9/3/2002 |
972 posts |
2 |
Posted:6/23/2005 07:27 |
Re driving lites...
any vehicle can handle driving lites....
if you're talking about the stock fog lights, I would recomend aftermarket lights - better - cheaper - and can be controlled by a relay to come on with an electrical signal u choose...
good luck !
JB
2003 6.0L 4x4 Limited Ex - traded in (BooHoo )
Ozzie
15 posts |
Posted:6/26/2005 08:14 |
Thanks for helping me out, both of you guys.
My wife asked about the door locking feature.
I was wondering on the driving lights , if there is a bulb inside the headlights that is the second driving light for the daytime lights. Maybe this is a toggle feature also?
Thanks. |
DFW, TX, USA |
972 posts |
2 |
Posted:6/27/2005 08:52 |
You have daytime running lights on a 2001 ????
Neither my 02 nor 03 had them - didn't know the Ex's even came with them
shiepo
carson, CA, USA |
Registered on 6/23/2011 |
75 posts |
Posted:1/30/2012 18:19 |
| Quote: | Thanks for helping me out, both of you guys.
Thanks. |
do you really have a daytime on yours? anyway i just wanna ask on how do you remove the headlights on your car? |
