nhoj
Hanover, PA, USA |
Registered on 1/9/2006 |
37 posts |
1 |
Posted:6/23/2008 07:02 |
I notice in the repair manual that the automatic transmission requires Mercon, not Mercon V or Mercon/Mercon V. There is even a caution note stating this. In preparing for a transmission fluid and filter change, I find out that Mercon is no longer made and that Fords service bulitin ows says Mercon V is OK to use. What's with the contradiction? It's OK just because Mercon is no longer manufactured??
Any thoughts?
01' Excursion V10 4X4
The Big Island, HI, USA |
Registered on 1/5/2002 |
1,056 posts |
2 |
Posted:6/24/2008 17:47 |
MERCON V was reformulated to work in transmissions that required MERCON. You're fine although I still wouldn't mix the two. If you change to V then make sure you drain the tranny sufficiently.
