aklim
Hartford, WI, USA |
Registered on 2/20/2006 |
133 posts |
Posted:6/12/2009 00:44 |
I would suggest running both types for a few cycles. Run a few cycles of synthetic and at the end of the 2nd one, send it off for analysis. Do the same for conventional and let them tell you what the change interval for each should be. That way you can make a financial decision.
01 Excursion. Gauges with AIH Delete, AIS Air Filter system, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F6 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BDP Stage II AC injectors. Bilstein Shocks with U code front and A code Rear. Billet thermostat housing |
