power rear vents
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 1176
TEEG
• Tifton, GA, USA
• Registered on 2/7/2010
Posted:5/2/2010 13:10
I have 2000 Limited V10. The power rear vents will not work. Fuses look okay. Any suggestions? Thanks.
nhoj
• Hanover, PA, USA
• Registered on 1/9/2006
• 37 posts
1
Posted:5/2/2010 16:41
this has happened to me as well. It was as simple as prying the window carefully while someone pushes the button to open. If the windows have not been opened for a while and sits outside, the window glass sticks to the rubber weather stripping. After you get it opened, if this works, clean the weather stripping and apply WD-40.
01' Excursion V10 4X4
Subscriber since 11/23/2003
Posted:5/4/2010 17:18
If you don't like the smell of WD40 in your truck, try some ArmorAll, or better yet, use Lemon Pledge. BTW, Pledge works great on tires, too. The owner's manual in my '01 said to lubricate all the rubber seals regularly with a silicone-based kind of fluid ... and that includes all the door weatherstripping.
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
1
Posted:5/5/2010 10:44
I use that heavy silicone tire shine and wipe the excess with a sponge--works great for me. You'll be amazed how many squeaks and groans it eliminates.
edited 5/5/2010 10:45
TEEG
• Tifton, GA, USA
Posted:5/7/2010 08:17
Makes perfect sense. Thanks for the tip!
TEEG
• Tifton, GA, USA
Posted:5/11/2010 10:50
I thought all of the fuses were okay until I checked the fuse box under the hood. You guessed it. Blown fuse.
power rear vents
