Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ 1987 F-150 5.0 liter 2WD King Cab Transmision
2 posts 2 contributors 1,308 views
PR
president01OP
Dec 3, 2011 at 4:27 AM
When I first start the truck in the morning, drive does not immediately engage. I put it in drive and it just sits there.. After about ten seconds or so, it grabs and the truck runs fine, shifts fine(in all three speeds) and no other problems til the next morning when this process starts over again..Any ideas?? Please tell me there is a quick fix, truck is rather old and I need it for work.. Thanks
WI
wizzard1222
  • Member since Jan 2011
  • 139 posts
  • Ballwin, MO, USA
Dec 3, 2011 at 2:24 PM
I don't have a full answer for your issue....My 1991 Lincoln TC Exec...4.6 L. 3 speed w/OD...std. AOD
does the same thing during cool/cold weather....
I have changed the filter-N-fluid and check the levels regularly. I think its a mater of bring the trans fluid upto proper temp range so that it expands to capacity and therefor applies the proper PSI pressures in the various gears 1-3 and overdrive.
Of course as you know of the existing issue....@ the beginning of the morning (initial startup) run....drive slowly & carefully to stop signs.....crossing traffic...etc.
Hope this is helpful...
