1995 f150 5.0
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 2617
ldinohio
• Bowling Green, OH, USA
• Registered on 11/20/2016
Posted:11/20/2016 15:12
Hey anyone have any ideas I have a 1995 f150 5.0 starts great in morning idles high normally then drives 2 miles to work perfect. sometimes about 2 out of 10 times after 8 hrs. work when I start motor it will stall then you have to push gas pedal to the floor to get started then fan throttle to keep running. After motor is warm then runs great. I thought maybe problem with IAC so I replaced but still problem. Thanks for any ideas!!!!! Dave B.
rdpsmn
• North Pole , AK, USA
• Registered on 9/14/2017
Posted:9/14/2017 00:23
I had the exact same issue with my 93 5.0 F150. When I got the truck I could only use the rear tank but he gave me the pump for the front tank. I changed fuel filter, plugs and wires, fuel pressure regulator, played with the timing, put on a new exhaust manifold, cut the cat converter off, and nothing changed. I had given up. I had nothing better to do one day so I put the new fuel pump on the front tank and what do you know, runs like a champ now. I was getting fuel just not enough. But the confusion was how it would run great first thing in the morning and then I would be lucky to make it home from work after it sat all day.
1995 f150 5.0
