Running board bulbs
Thread Statistics:     Users to Post: 10   |   Total Posts: 18   |   Total Views: 9553
Jon R
• manchester, NH, USA
• Registered on 1/29/2003
• 17 posts
Posted:6/19/2003 17:02
does anyone know the bulb number for the running board lights?
also, how do you remove them, they seem to be in pretty tight
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:6/19/2003 17:27
I beleive they are 194's! There are two screws around the housing that hold the bracket in. 10mn i think
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Jon R
• 17 posts
Posted:6/19/2003 20:36
Thanks once again Scott!!
Joe Ferras
• Miami, FL, USA
• Registered on 7/2/2003
• 14 posts
Posted:10/8/2003 18:03
I put some blub bulbs on my runing boards and they look really sharp not so bright when you open the door lumination is perfect you can pick them up at any auto discount stores make sure the are true blues glass not the painted ones[quote]
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:1/5/2004 18:11
Hey. nifty idea.. I'm going to put some blue bulbs in this summer when I do the yearly maintenance thing.
Those screws can be a real pain. I oiled mine when I took the bulbs out to dump the water out. I'll find out how that worked out next summer. :-)
I may go one step further and use a Blue LED. Light bulbs be damned.
Dave.
edited 1/5/2004 18:13
David Killough
• Seattle Area, WA, USA
• Registered on 1/9/2004
Posted:1/11/2004 13:44
I had a running board light out on the front drivers side. I removed the two nuts and swung the cover plate aside and found the connector full of water, much to my chagrine. After cleaning and replacing with a new bulb - it works fine. I plan to go to clear LED lights, but must choose between 1 LED, 2 LED's...up to 4. Has anyone try any of these? I am curious which one is an equal in brightness...
Posted:1/11/2004 19:08
I've purchased some clear reverse lights that I plan to mount BENEATH the running boards, and light up the ground below. My ex-girlfriend's E.B. Explorer has some lights on the bottom of the exterior mirrors that light up the ground, and is a really helpful feature when entering/exiting. Figured I would get the same benefit by adding some underneath the boards .... and of course I'll include some rock-protection for all the debris kicked up by the front tires.
birdman127
• 581 posts
Posted:1/11/2004 19:29
Ford sells that as a kit Landyot! I looked in to it after i bought the auot headlamp kit from them. It also has DRL but i will disable them most likley.
Moderator
Lots of mods
check my gallery
Posted:1/11/2004 19:42
Ford offers that? Cool! Guess I can install the already-purchased lights as reverse lights on my car trailer. Thanks for the tip!
David Monach
• Orange County, CA, USA
• Registered on 6/30/2002
• 38 posts
Posted:1/12/2004 22:46
How easy was the auto headlamp kit to install. I am terrible with the electrical wiring stuff. The last two cars I have own have the auto headlamp thing and I miss it on the beast.
Let me know!!!
Running board bulbs
