Trans problems at 44k
Thread Statistics:     Users to Post: 2   |   Total Posts: 7   |   Total Views: 699
Scott Coats
• Ft. Lauderdale, FL, USA
• Registered on 1/8/2003
• 84 posts
Posted:7/26/2003 09:38
Over the past few days my transmission doesn't want to shift out of first without me getting up to 20 MPH and then letting off the accelerator. It has gotten worse and I am taking it to my mechanic on Monday. Any suggestions/ideas? Fluid is full and doesn't smell/look burned. Changed the fluid at 27k.
Thought it might be the chip, so I took that out--no change and it was worse last night. Not driving it any more until I get it checked out.
Wish I lived near Gearman :-)
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:7/29/2003 13:04
sorry i could not get on the net for a couple of days. get the truck scanned, it might not be that serious. if you need help with decifering codes let me know.
mike
Scott Coats
• 84 posts
Posted:7/30/2003 05:51
Scan said "first-second shift error". I sent you an email asking for your phone number so I can disucss building a stronger setup.
edited 7/30/2003 05:55
gearman
• 336 posts
Posted:7/30/2003 09:20
my phone # 310 674 4400. i need the code ref. #. it may not be serious at all.
mike
Scott Coats
• 84 posts
Posted:8/9/2003 12:08
Hi Mike, thanks for speaking with me on the phone about my trans problems. Great info!
To catch others up, took the X to the Ford dealer and had the trans "fixed". Back from the dealer this past Monday and still have the same problem and same EEC codes, P1744, P0781, and P0732. I didn't see the solenoid pack on the list of parts they replaced, so i am guessing that's the latest problem.
I will order the converter/shift kit from Mike when it's available. Mike, be sure to call me when th converters are ready for sale, 561-762-8199 anytime. Any point in doing the shift kit without the converter upgrade?
I also picked up a Banks Trans Command (used). Any point in installing this with the shift kit--any advantage?
Scott Coats
WPB, FL
gearman
• 336 posts
Posted:8/9/2003 19:17
i have the converter and shift kit in stock. before we do anything, lets address your codes first. i have noted the numbers and will research the possibilities at work monday. i would like to know the exact symptoms in detail. would like to talk to you. if you are available sunday email your phone # and ill call or i will give to my home phone #.
regards, mike
gearman
• 336 posts
Posted:8/9/2003 19:20
DUH i just realized you posted your phone #. sorry i will call you sunday.
