fornt spring ID
Thread Statistics:     Users to Post: 5   |   Total Posts: 14   |   Total Views: 1593
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:9/6/2003 10:33
I replaced my front springs with 2003 f-250 "V" code springs. After crawling around on the ground I found these numbers as;
2C34 ADB
R 225 2
on edit thats what he told me(2003)? They did lift my X almost 2 full inches
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
edited 9/6/2003 10:37
glenn z
• harrison twp., MI, USA
• Registered on 8/22/2003
• 63 posts
Posted:9/6/2003 15:21
seethis is the type of info people need,
the YC35 *** are stock excursion
the 2C34 *** are V codes
how about the other=r user
what do your X code, U code, and T code springs read
this is the type of list that needs to be compliled
glenn z
www.mtrperformance.com
birdman127
• 581 posts
Posted:9/6/2003 20:34
glenn z
The code's are on the bottom of the spring under the door on either side. I agree we need to compile this into a graph something like bruce did with the springs lift over stock.
Moderator
Lots of mods
check my gallery
Phil Eaton
• Lander, WY, USA
• Registered on 4/28/2003
• 42 posts
Posted:9/6/2003 22:04
For what it is worth, at the end of each spring where the end is rounded for the shackle bolt, there is a paint dot with an embossed letter. It is visible for the installers on the assembly line as the springs are stacked in crates. That is where the v,x,u etc. codes are designated and originate. Makes things a little easier for guys installing one a minute like I once did 23 years ago on other ford trucks.--the codes where different then of course--
fornt spring ID
