2001 Diesel X front spring height
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 476
Greg Hittner
• Costa Mesa, CA, USA
• Registered on 7/14/2003
• 13 posts
Posted:9/18/2003 12:26
Can someone direct me to a chart that I saw regarding the ride hieght and rate differences of the stock Ford front springs when installed on the X with a Powerstroke? In particular there is a stock Ford spring that will level the vehicle without increasing hte rate and thus sacrifice ride quality. Thanks, Greg
cwbyinjeep
• Registered on 8/5/2003
• 47 posts
Posted:9/29/2003 10:45
Do a little bit more searching. I researched this a couple months back and the answer was going with a V rated front spring from a quad cab dually 4x4 I believe. It will lift the front of the X approximately 1-2 inches, but I have not tried for myself as of yet.
Bobby Wooldridge
BMW Motorcycles of Atlanta
ken J
• Angola, IN, USA
• Registered on 8/17/2003
• 9 posts
Posted:9/29/2003 16:33
Here you go, it was in the main EX forum, page 3 i believe
Found this Spring info
Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
------------------------------------/spring---to Max Cap ----height ----height
---------------------------------------------------------------- change --- change
Exc V8 -------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 ----- -0.66
Exc V10 ------ C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 ----- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ------ 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependant
Application---Code---Capacity-----Rate----Travel ------------- V-10 ----- PSD
--------------------------------------- /spring---to Max Cap ----height ----height
------------------------------------------------------------------ change --- change
SD-250/350
------------------ S --------4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
------------------ T --------4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
------------------ U --------4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
------------------ V --------5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 ----------- W --------5600 ----- 450 ------ 5.34 --------- +2.77 --- +2.52
F550 & 350/ DRW with Snow Plow prep Package
----------------- X-------- 6000 ----- 470 ------ 5.54 ---------- +2.90 --- +2.68
posted
