2 more questions
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 568
dnp
• Jackson, MS, USA
• Registered on 1/20/2003
• 37 posts
Posted:1/31/2003 10:36
(2000 X V-10 Limited 4x4)
As I sort out this new acquisition, I continue to have questions for this forum:
1. At 70 mph, I'm turning about 2450 RPM.......would that most likely indicate 3.73 or 4.30 gears?
2. At about 2200 RPM, I'm experiencing a very noticeable vibration from the drivetrain (just like what you'd experience if the exhaust came in contact with a crossmember/frame/body - however, I've checked, and the exhaust has plenty of clearance along its entire length). This vibration occurs exclusively from about 2200 to 2500 RPM........any source known for this vibration? If so, any cures known?
As always, thanks for your input,
dnp
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:1/31/2003 13:19
4.30 gears
Mine did that when I got it (used) and it turned out to be the drive shaft. It had "excessive runnout". My dealer replaced it at no charge to me. Probably because I had complained and said I would not buy it unless they stopped the vibration/drone.
Another thing they did was put a vibration dampner on the exhaust just behind the muffler.
Let us know what it is. Good luck.
Rick
2004 VW Jetta TDI
edited 1/31/2003 13:20
Posted:1/31/2003 19:51
( This vibration occurs exclusively from about 2200 to 2500 RPM........any source known for this vibration? dnp
In EVERY gear?
If only in overdrive then I would tend to agree with Rick.
But also check to make sure your front hubs are unlocked properly. Sometimes they can stick.
dnp
• Jackson, MS, USA
• 37 posts
Posted:2/1/2003 14:22
In EVERY gear?
Thanks for the responses.......
Yes, I get the vibration in every gear (similar to a drone, but you can feel it, rather than just hearing it), which leads me to believe it's an exhaust vibration issue.......Rick, do you know what type of exhaust dampner they used on your exhaust? Is it a Ford problem-solving piece or was it simply a weight of some type? Any way you could take a photo and send it to me? (I hate to ask for that, but I want to try to duplicate the piece you've found to be successful in curing this sensation) When you mentioned the dampner, that sounds exactly like what my truck needs.....please advise
David
RS-TX
• 298 posts
Posted:2/3/2003 13:57
AFAIK it is a Ford factory piece.
I'll have it on it's merry way as soon as I finish this post.
It is absolutly no problem. Glad to help.
David
I hope it helps. Let me know. Picture will be on its way momentarily.
BTW, sorry it took me so long to reply. I was busy doing "honey-do" jobs all weekend. It was sunny and in the upper 60s all weekend. Beautiful weather!
Rick
2004 VW Jetta TDI
edited 2/3/2003 14:02
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:2/3/2003 14:49
i have felt a torque converter clutch do this also.a quick scan can answer that question
mike
2 more questions
