Rear leaf spring question?
Thread Statistics:     Users to Post: 6   |   Total Posts: 7   |   Total Views: 1111
ehumaui
• Santa Clara, CA, USA
• Registered on 1/26/2003
• 36 posts
Posted:1/31/2003 13:02
Under the rear leaf pack, there is long piece of steel with a rubber bump stop on it. I that what they call the overload spring?
Russell
2000XLT V10 BBk throttle body, throttle body spacer, KN flpk, Skyjacker 6" lift, Eagle alloy 589, 35" Xterrains, Rancho 9000, Firestone air springs rear, Hellwig rear sway bar, Warn Rio Grande push bar, Custom rear tire subwoofer, custom Zoo dad mod, Too may tire changes since I lifted it!
Posted:1/31/2003 19:53
No, that is called an anti-wind up spring. It is there to prevent axle wrap because the springs on our Excursions are quite soft and can make axle-wrap more pronounced.
203008581
• MONTGOMERY, AL, USA
• Registered on 11/22/2002
• 73 posts
Posted:2/1/2003 13:27
OK, I need spring training 101. What exactly is axle wrap?
edited 2/1/2003 13:28
Posted:2/1/2003 16:29
Okay....
Basically axle wrap is when the axle tries to spin the opposite way of the wheel. There are some cool mechanical & physical forces at work here.
When you have soft (read: not strong) springs is accentuates this. This is because the spring in not strong enough to resist the movement.
The lower spring is designed much like a short traction bar you saw as a kid on that cool dude of the neighborhood's Camaro hot-rod.
A larger example are ladder bars that you will find on extreme lifted trucks. Especially those with air bag suspensions.
If you need a more detailed explaination then I'll be more than happy to provide it and give examples of the forces that create axle wrap in everyday life.
edited 2/1/2003 16:41
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:2/1/2003 18:48
Glad to have you back responding Monsta
The_X_Family
• Northern, CA, USA
• 63 posts
Posted:2/1/2003 22:45
This site explains this and other things very well..... I like it.... I has pictures!!
http://www.4x4wire.com/jeep/tech/susp/axlewrap/
Ken D.
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:8/20/2011 01:18
Under the rear leaf pack, there is long piece of steel with a rubber bump stop on it. I that what they call the overload air springs?
Russell
monsta is right. when i was having the same problem i went to my mechanic and he told me that.
