rumbling sound
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 446
adel bishar
• ann arbor, MI, USA
• Registered on 9/26/2003
Posted:9/26/2003 21:14
help I have 2001 excursion powerstroke with a rumbling sound between 45 mph to 60 mph ,
any body help Iam at my wits ends, thinking it was thetires i went and put new tires on X still the same problem, it feels like i am driving on a wash board, it clears up when i get to 70mph
edited 9/26/2003 21:51
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:9/27/2003 18:52
Torque converter clutch is breaking loose. Here is a test you can perform; you will have to be a two footed driver for this. Bring the X up to speed and let it begin the rumble and hold the rumble steady, while you are doing that, lightly tap brake pedal and see if it goes away. You may have to practice it a bit to do the test and it wont hurt anything. Depressing the brake pedal electronicaly releases the converter clutch, and if i am correct, rumble will go away. It should come right back after you leave the break pedal alone. It will only take a few minutes to do this. Remember to do it when the engine is warm because sometimes lock up is inhibited when engine is cold; depends on computer calibration. If you have any questions, dont hesitate to ask.
regards, mike
Tom boucher
• Houston, TX, USA
• Registered on 8/27/2003
• 43 posts
Posted:9/28/2003 08:09
Wheel bearing possibly, or is that present at all speeds?
Tom Boucher
1 Wife
Too many kids
AND NOT ENOUGH TRUCKS!!!
rumbling sound
