Door code.
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 634
Doug Loper
• Byron Center, MI, USA
• Registered on 9/26/2003
• 114 posts
Posted:10/5/2003 09:14
I just picked up my 2000 Excursion yesterday from a small dealership out of state. He did not know the code for the keyless entry on the door, a friend told me for puts the original code inside the vehicle somewhere. Usually under the dash. I've looked but did not see it anywhere. Can anyone point me in the right direction? Maybe I will have to contact Ford dealer tomorrow, just wanted to get it set up today if possible. Thanks, Doug.
2000 X V-10
Mods: 6" Revtek lift
35" M/T Baja Claw Radials
16" x 10" Eagle Alloy Rims
SilverStar 9007
Clear front corners.
Mike & Jody Plassa
• Subscriber since 3/14/2012
• Yardley, PA, USA
• Registered on 8/8/2003
• 59 posts
Posted:10/5/2003 10:40
Doug,
I've seen many post that say some earlier X's default code can be found on a sticker attached to the bottom of the ecu behind the left kick panel. To date I have had no luck and I've checked aproximately 10, 2000 to 2002. At any rate your dealer can read the code from the computer, I had it done about two weeks ago, it took about 15 minutes and they didn't charge me. I believe this is your only alternative.
Mike
Doug Loper
• 114 posts
Posted:10/5/2003 18:59
Thanks for the help. I'll contact one of the dealers here.
2000 X V-10
SilverStar 9007
Door code.
