Front Sway Bar Bushing fitment...
Thread Statistics:     Users to Post: 1   |   Total Posts: 1   |   Total Views: 487
Cobra427
• Fremont, CA, USA
• Registered on 1/24/2003
• 37 posts
Posted:10/5/2003 19:12
(I posted this on Ford-Trucks.com, also...)
I have a 2000 Ford Excursion Limited 4x2 with a V10.
I purchased an Energy Suspension 4.5180R Front Sway Bar Bushing, and I am having a problem. The bushings fit fine onto the front sway bar, however the U shaped mounting bracket doesn't fit at all. The U shaped mounting bracket is too narrow. In other words, the new bushing is wider then the U shaped mounting bracket.
Did I purchase the wrong bushing, or do I need to purchase new set of U shaped mounting brackets. And if the later, then can you advise me of the correct part number to order?
Randy R...
