ReCalibrating Speedo for larger tires,
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 466
• 0 posts
Posted:10/20/2003 16:20
Does anyone have the cheat sheet for this?
I have done this on my 94' bronco. Is it the same for the X?
And,
I tried searching. But unless i am missing something there is no where to search. And superfords search is down too.
Weatherlite
• Mountain Home AFB, ID, USA
• Registered on 10/21/2002
• 133 posts
Posted:10/21/2003 12:58
go to Superlift's website. The X uses an electronic sensor that the computer uses to determine how fast you're going...problem is that the computer is programmed with what ratio axle you have. So, if you change axle ratios you can just re-flash the computer. If you change tire size you have to "trick" the computer a bit.
Superlift's speedo calibration module takes care of everything. Just a bit expensive. Check out Ebay if so inclined...last one I saw on there went for about half of retail.
Good luck!
Mikie
