ABS and OD Lights
Thread Statistics:     Users to Post: 5   |   Total Posts: 12   |   Total Views: 1690
Glenn Dugger
• Dallas/Fort Worth, TX, USA
• Registered on 10/28/2003
Posted:10/28/2003 17:07
My ABS light is on steady, overdrive light flashes, and speedometer doesn't work. All fuses check OK. Transmission seems to shift at normal speeds. I hate to take this to the local Ford dealer 'cause I'm out of warranty and they have a habit of over-charging. Any ideas?
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:10/28/2003 19:57
When you drive it next, watch your speedo and see if it does anything weird. I'm willing to bet it's probably your $12 speed sensor in your rear diff. It's an easy fix if that's what ends up as the problem.
Kevin Curry
[email protected]
http://www.texas4x4.com
Glenn Dugger
Posted:10/29/2003 07:40
The speedometer works sometimes. Othertimes it's dead. Does this sound like it's the sensor on the rear diff?
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:10/29/2003 08:23
I think we hit it on the the head. I picked one up from the Ford Dealer when same thing happened to me. Like I said, it was about $12 at the dealer and was a piece of cake to install.
Kevin Curry
[email protected]
Glenn Dugger
Posted:10/29/2003 11:56
Thanks Kevin, you're correct. A new speed sensor on top of the rear diff fixed the problem.
A quick fix but the local ford dealer charged $26.
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:10/29/2003 13:42
No problem. When it happened to me in my F250, I thought it was going to be catastrophic. Thank goodnes for forums like this!
Kevin Curry
[email protected]
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:10/30/2003 10:38
You guys are good! I have found that a lot of enthusiasts have more knowledge about their trucks than a lot of so called techs.
mike
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:10/30/2003 11:41
No kidding huh? You gotta wonder how we lived without the Internet less than 10 years ago!
Kevin Curry
[email protected]
Weatherlite
• Mountain Home AFB, ID, USA
• Registered on 10/21/2002
• 133 posts
Posted:10/30/2003 12:22
10 years ago we could still do our own diagnosing! Even on computer controlled cars we could pull the codes using a 12V light and a jumper wire (Fords) or just a paperclip (Chebby) and then fix it ourselves. For todays you have to buy those expensive readers and even then it's just a code reader...doesn't do all of the neat stuff the dealer's tools can.
Mikie
gearman
• 336 posts
Posted:10/30/2003 13:02
Mikie
The dealers dont seem to be doing so well with their neet stuff.
ABS and OD Lights
