? am i nuts? i dont think so.but maybe
Thread Statistics:     Users to Post: 6   |   Total Posts: 10   |   Total Views: 652
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:10/30/2003 21:15
When i got my X i noticed the usuall wander in the steering. When i did my first oil change i gave it a lube and noticed some of the wander disappeared. I noticed recently that the X wanders more than before and when i did my oil change i found my grease gun broken. I will pick up another this weekend. Have any of you people noticed what i did? Have i become a demented old codger?(don't answer that). I will lube the X next week and see.
mike
Phil Eaton
• Lander, WY, USA
• Registered on 4/28/2003
• 42 posts
Posted:11/4/2003 13:55
Mike, let us know about the greasing. If you don't mind me asking a non-x question as I have seen you advocate gear changes for performance improvement. I have a 98 f150 4.6, 4wd, powerdyne supercharger, cat back exhaust. Combo runs well, but has always lacked bottom end. Currently have factory 3.73 ring and pinion. I am considering a 4.3 front and rear with an electric locker for deep snow. I don't know if this combo will be worth the $ and I don't know the effect on the highway rpm. Most of my driving is 65mph and less. I live at high altitude in mountainous terain. Your thoughs would be appreciated.
ps. are there worth while improvements to be had on the transmission side?
spartan
• Nashville, TN, USA
• Registered on 7/17/2003
• 87 posts
Posted:11/4/2003 14:24
Gearman - I don't think your nuts, probably just very sensitive to the way your truck feels and handles like a alot of us on this forum. Full greas fittings would make sens that there would be less slop. I try to keep mine full. I just wish the truck had about nine more like my Lancruiser: every u-joint, slip joints, steering knuckles, etc..
gearman
• 336 posts
Posted:11/4/2003 15:05
spartan
i agree about the grease fittings. the main reason you dont have grease fittings in your u-joints is that it weakens them because they are hollow.( one less liability).
gearman
• 336 posts
Posted:11/4/2003 15:13
Phill
i dont know whether spending the money on the diffs is worth it. it most defenitely will help a lot bringing the RPMs in quicker to allow your blower boost to work sooner (that is a problem with centrifical blowers, they are like turbos working better in the upper ranges not down low where a truck needs it). there are a lot of things we can do in the transmission to make it stronger but not help power with a 4.6. a twin screw blower like Kenne Bel would help low end a lot, but thats a lot of money. gears with a locker would probably run 1500.00 or so. maybe it's the way to go.
mike
Phil Eaton
• Lander, WY, USA
• 42 posts
Posted:11/5/2003 12:53
Thanks Gearman, I'd like to buy a transmission kit from you. Your shop is too far for me to travel, so I would like to try the installation myself if you think that is doable. $1500 is about what I thought for the other. What ratio do you think would be best?
Thanks again, Phil
neilc88
• Cleveland, OH, USA
• Registered on 8/13/2003
• 53 posts
Posted:11/5/2003 15:33
mike
Maybe I am the one that is nuts. My wife and I don't notice the wander in our X. I've driven it from Cleveland to Maine and back two times and just don't feel this problem. Also, I do grease the fittings but, have not noticed a difference before or after. Even after reading the forums and trying to find the wandering, I don't. Maybe I have the perfect alignment, or maybe it is good enought that I can't tell otherwise.
gearman
• 336 posts
Posted:11/5/2003 17:29
neilc 88
Maybe it doesn't take much to please you. j/k
I don't know if all X's wander, but a lot of them do. When i picked mine up back in Feb. i notice a big wander. after lubing the fittings things got much better. now it's back (still havent bought new grease gun, soon )
mike
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:11/7/2003 15:51
neilc 88
mike
Mike bring your truck to Baltimore I'll lube it! I just got a gun and mobil 1 syn grease! While your here can you bring me a converter and a kit for the tranny?
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:11/8/2003 02:14
I have not seen any wandering either and its something I hate.
And I have not noticed any difference after a greasing either.
Wife had an explorer that liked to wander to the left. Ford dealer tried too and never did fix it. We got rid of it and bought a focus just to spite them.
Dave.
