Hellwig Swaybar Install
Thread Statistics:     Users to Post: 10   |   Total Posts: 15   |   Total Views: 2959
Posted:11/23/2003 08:44
Monsta - I tried sending an e-mail to you concerning your idea (I like it), but the message was returned as undeliverable (your e-mail address apparently isn't working properly in your profile). Send me an e-mail, please, and I'll send my original message via reply. Thanks
John Doe
• Dallas, TX, USA
• Registered on 11/27/2003
Posted:11/30/2003 22:09
Can anyone tell me what the advantage of the Hellwig sway bar is over buying a ford rear sway bar for a 2003 X?
Mine is a 2002 X, and I obviously don't have one now, but which is better the Hellwig, or a ford facotry one to fit the newer model X??
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:12/1/2003 16:40
Hellwig is a beefier unit and most likley cheaper at 145.00.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Posted:12/1/2003 21:08
John,
Some have said that the Ford 30 MM rear bar is a bargain...
but I've not seen or compared it... I THINK I recall that someone did and said the Hellwig was thicker - which relates to more sway control...
I had an '02 Ex 4x2 and I can tell u the hellwig imprved my 'comfort' feeeling in corners 1000 % !!!
I'm even considering swapping out my '03 4x4's chincy little stock bar for the hellwig to get better control....
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:12/1/2003 21:39
You will get more sway with the Ford bar. When i installed my bar i set it tight; by that i mean i used the higher hole in the frame and when i tightened the bar to the lower link, it drew up a little. That tells me the the bar is in play at all times. IMHO
mike
