Brake controller...
Thread Statistics:     Users to Post: 7   |   Total Posts: 17   |   Total Views: 1977
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:11/8/2003 02:37
Do I read this right? Is there no Factory brake controler on the ex?
Pardon my ignorance but whats this gizmo all about?
Dave
Posted:11/8/2003 08:46
The brake controllers we're talking about are electronic devices for actuating (controlling) the electrically-operated brakes found on heavier trailers. Trailers over a certain weight must have their own brakes. Hence, the tow vehicle needs a means to operate those brakes.
Boat trailers use hydraulic systems with an impulse-type master cylnder mounted at the tongue of the trailer .... as the vehicle slows, the forward-pressure of the trailer applies the hydraulic brakes.
edited 11/8/2003 08:47
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:11/11/2003 08:34
Thanks for the help guys! I received the controller in the mail yesterday and it took ~10 minutes to install - most of which was the time it took to reach said connector under the dash with my large hands. It was right where you guys said it was, though.
Kevin Curry
[email protected]
http://www.texas4x4.com
Superdogsteve
• Katy, TX, USA
• Registered on 5/18/2005
• 20 posts
Posted:10/22/2007 14:43
I recently bought a prodigy brake controller and the adaptor that is plug and play.
The strange part is that when I plug in the controller it is flashing "SH", which shows to mean there is a short in the wiring. This is before I ever connect the trailer.
Has anyone else had a simailar problem?
STEVE K
'05 X Limited 4X4
2005 X Limited 6.0L stock
Lead, Follow, or Get out of the way!
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:10/23/2007 08:37
STEVE K
'05 X Limited 4X4
I doubt it's going to be with your controller. I would check the adapter at the back of the truck for chaffed wire insulation or loose conntector.
Kevin Curry
[email protected]
Posted:10/23/2007 19:04
The strange part is that when I plug in the controller it is flashing "SH", which shows to mean there is a short in the wiring. This is before I ever connect the trailer. Has anyone else had a simailar problem?
The following is what I posted on Page 1 of this thread ...
Let me add a big word of caution here. I found that the adapter plug I bought ... the part that gets spliced / soldered / heat-shrunk to the brake controller wiring was mis-identified in regards to wire color. If I blindly followed their directions, I probably would've fried the Prodigy unit. So, before you finalize any connections, make certain you've tested the functionality of each wire ... and this is when a multi-tester / Ohmmeter comes in handy.
Another mis-labeled document I found was in the FORD Factory Service manual for the 7-pin trailer receptacle. The manual had most of the wires mis-identified. After I obtained a generic copy of how they're supposed to be wired, I found the X was wired correctly, but the OEM manual was wrong.
You may have another adapter that was assembled incorrectly.
edited 10/23/2007 19:06
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:10/24/2007 09:49
[color=blue]Let me add a big word of caution here. I found that the adapter plug I bought ... the part that gets spliced / soldered / heat-shrunk to the brake controller wiring was mis-identified in regards to wire color. If I blindly followed their directions, I probably would've fried the Prodigy unit. So, before you finalize any connections, make certain you've tested the functionality of each wire ... and this is when a multi-tester / Ohmmeter comes in handy.
Another mis-labeled document I found was in the FORD Factory Service manual for the 7-pin trailer receptacle. The manual had most of the wires mis-identified. After I obtained a generic copy of how they're supposed to be wired, I found the X was wired correctly, but the OEM manual was wrong. [/color]
Good point. I totally forgot about that.
Kevin Curry
[email protected]
Brake controller...
