ABS Light
Thread Statistics:     Users to Post: 5   |   Total Posts: 8   |   Total Views: 460
Coach3rd !!
• Chesapeake, VA, USA
• Registered on 1/21/2003
• 43 posts
Posted:11/10/2003 15:54
What can it mean if the ABS light comes on and stays on. Is it still safe to drive? I looked in the owners manual and it says to have it serviced immediately. Anything I can do to fix what is wrong?
Jeff
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:11/10/2003 16:19
Is that the only indicator you have? O/D light not blinking or anything? No other anomalies?
Kevin Curry
[email protected]
http://www.texas4x4.com
Coach3rd !!
• 43 posts
Posted:11/10/2003 19:17
No ther indicators. As a matter of fact I just went out to check again and the ABS light is not on now??? I started it up and it went out as usual. Anybody else seen this happen? ABS light comes on driving home. Then goes off after a while???????????
Orf
• Pittsburgh, PA, USA
• Registered on 8/29/2003
• 143 posts
Posted:11/11/2003 09:25
My previous vehicles (a '97 Expedition and an '03 Expedition) would do that when the brake fluid was low. The fluid was usually low when the pads were worn, so the fix was to put new pads on, which pushes the calipers back, which raises the fluid level, which turned the ABS light off. Not sure if it works the same in the Excursion, though.
Coach3rd !!
• 43 posts
Posted:11/12/2003 13:28
Now my check engine light is on along with the ABS light. Whats up?
Stephanie Motzer
• Anthem , AZ, USA
• Registered on 4/3/2003
• 27 posts
Posted:11/12/2003 13:30
It may be the speed sensor. That was the case with mine.
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:11/12/2003 13:38
Scan it before you throw money at it.
Coach3rd !!
• 43 posts
Posted:11/13/2003 16:10
Had it scanned today. Turns out it was the VSS (vehicle speed sensor).
Replaced it and no more lights.
ABS Light
