One more issue (lock actuator)
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 567
PJDAD
• Manchester, NH, USA
• Registered on 11/10/2003
• 12 posts
Posted:11/10/2003 21:32
I've been reading about the lock actuator. Would this also cause the power door lock fuse to continually blow? Sometimes it won't blow for months, sometimes only days though. I've replaced about 6 fuses in 6 months. The left passenger lock sticks at times...could this cause the problem? Thanks again,
Don
Just our suped-up version of the old station wagon!
-Don
RickyG
• Lubbock, TX, USA
• Registered on 5/10/2003
• 24 posts
Posted:11/10/2003 22:23
Don, I would vote yes on that subject. I personally have replaced all four of my actuators on my 2000 X. On my truck the locks started sticking, then a couple of weeks later they eventually did not work at all. If they are under warranty, get them changed asap. If they are not, you can buy them online for $50ish and change them yourself. I had mine done under my extended warranty along with one window motor and the bill was around $850! Too bad for my warranty company. Good for me! I hope this helps.
PJDAD
• 12 posts
Posted:11/12/2003 20:08
I'm pretty sure the normal fuse for the locks is 20 amps. I've been putting a 30 amp fuse in it and it still blows. I'm not too familiar with the electrical side of the beast, but if I put in a higher amperage fuse, could it possibly fry some components in the door lock system when there is another fault? Thanks...
Don
-Don
David Moore
• Houston, TX, USA
• Registered on 10/24/2003
• 9 posts
Posted:11/14/2003 10:22
Don,
I would not recommend putting higher-capacity fuses in. You're taking a chance on how much current your wiring and other components can handle. After all, 20 amps was put there for a reason.
I posted instructions on replacing the actuators a couple of weeks ago. It's probably on the next page now, title: "Door lock actuators - how to replace". Please read this. I'm on a mission to drive as much of this business away from the Ford dealerships as possible. They are really screwing us, and I'm not one to bend over and smile.
PJDAD
• 12 posts
Posted:11/15/2003 19:32
Thanks, I'll take a look at that thread...Ford dealer here is pissin' me off too ! I have the recurring problem of warped rotors. The Ford dealership here wants $140 a rotor! ART only wants $209 for a pair (and they're better). Thanks again...
Don
-Don
