no oil presure
Thread Statistics:     Users to Post: 9   |   Total Posts: 15   |   Total Views: 1299
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:3/11/2003 14:39
I've discovered that 15w40 is too thick for the present temp range..(below -13C) hard to get it started (some days not at all). I Thought it was the batterys acting up. Anyways, I've got 10w30 in it now and I'm waiting to see how it works.
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:3/11/2003 16:54
Yeah I know what you mean...I had to change my oil too. You know, it was to thick for these cold...OH WAIT it's 70 here right now, what am I thinking?!?!
MONGO
• Sandwich, IL, USA
• Registered on 1/3/2003
• 210 posts
Posted:3/11/2003 17:17
5w/20 for the V10
trauski
• indianapolis, IN, USA
• Registered on 3/10/2003
• 44 posts
Posted:3/13/2003 15:33
i had the same problem with oil pressure with my surburban a few weeks ago. it wold go to 5 psi at idle when warmed up. put on sending unit and got a 10 more psi at cold start up and normal drive speed, but still same problem. so i jacked up the motor and put a new oil pump in it.still same problem the beaarings had a little play but a mechanic friend so it was no more than any car would have so he thought the were ok.the low pressure was verified by an external oil gauge. so i sold the thing and bought a 2000 X the same day.
Chris Martin
• Berwyn, IL, USA
• Registered on 2/2/2003
Posted:4/13/2003 11:09
Have same oil issue of no oil on gauge. Only on cold weather starts(10 degrees or less). About 5 mins to clear. no lifter noise etc. even on rev-up no psi. seems more like gauge does not see.Fine in warmer weather.
no oil presure
