Compatibility question
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 428
Charles Fraley
• Lawrenceburg, IN, USA
• Registered on 12/11/2003
Posted:12/12/2003 10:42
Would the rotors and pads from a 2002 F250 7.3SD match a 2000 X limited 7.3? How would you check other components also?
Posted:12/12/2003 14:27
The 02 has a different front axle IF THEY ARE BOTH 4WD!
The rears are the same. Sterling 10.5
I'm just not sure if the front rotors from the D60 are compatible with the D50.
If they are both 2wd truck, then no problem.
edited 12/12/2003 14:31
Douglas Dircks
• New Richland, MN, USA
• Registered on 11/13/2003
• 118 posts
Posted:12/13/2003 09:21
You would guess they would be the same they both are the same bolt patern and fit in the wheel the same. I would call a local Ford dealer and ask them though just in case.
