RE: bigger tires
Thread Statistics:     Users to Post: 7   |   Total Posts: 7   |   Total Views: 1267
Gary Fakes
• St. Louis, MO, USA
• Registered on 12/13/2003
Posted:12/13/2003 16:18
Need new tires on my 2000 Excursion and want to know what is a good size for the vehicle. I have been told 285 75 16 and also 305. Does anyone have a tire that fills in the space and looks good?
edited 12/13/2003 16:36
spartan
• Nashville, TN, USA
• Registered on 7/17/2003
• 87 posts
Posted:12/13/2003 19:14
This one is really simple. 285's will go on your stock rims and run on your stock suspension. 305's require at least 8 inch rims and will rub without a small lift. Other's will tell you the 305's are fine, but they will rub. I have seen it first hand - no internet confirmations.
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:12/13/2003 20:02
My 285s rub the mud guard. Next time I will stay with 265. Probably highway tread, too. But the AT 285s do look good.
Rick
2004 VW Jetta TDI
MONGO
• Sandwich, IL, USA
• Registered on 1/3/2003
• 210 posts
Posted:12/14/2003 09:10
I`ve got 305 Nitto`s on MB Motorsports 8x16`s and have never rubbed( stock suspension). You will have to take off the mud flaps. There for sale. Got to get new wheels and tires(put on a lift). Going to 36"x14.5`s and maybe Crushers.
The set are only 3 or 4 months old, VERY low miles( I only drive the X on the weekends). There in perfect conditon. I realy like the Nitto`s. They are quite and have a great tread design. If anybody interrested, let me know.
glenn z
• harrison twp., MI, USA
• Registered on 8/22/2003
• 63 posts
Posted:12/14/2003 20:43
305's on stock rims, stock ride height, no rubbing on body, hits front spring only when turning really hard and hit bump, if turning full turn will not hit
mine is a 2000 X PSD 4x4
www.mtrperformance.com
edited 12/14/2003 20:44
Raymond Golson
• Piscataway, NJ, USA
• Registered on 8/19/2002
• 68 posts
Posted:12/15/2003 13:12
Bone stock 2000 Ltd 4x4 on 305 GoodYears w/stock rim, no rubbing or cutting was done and I had the factory mud flaps...
cwbyinjeep
• Registered on 8/5/2003
• 47 posts
Posted:12/15/2003 14:01
305 BFG's on stock rims 2000 4x4 PSD and no rubbing what so ever, 315's will rub the springs and wear very poorly and probably hit the mud/step rail However 305's on an 8 inch rim would probably rub, but 8 inch rim isnt absolutely necessary for that size tire where as a 315 has to have an 8" rim to have anything good to say about it.
Bobby Wooldridge
BMW Motorcycles of Atlanta
edited 12/15/2003 14:03
RE: bigger tires
