Tinny noise at between 1200 - 1400 RPM's
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 457
Beer Man
• Newton, KS, USA
• Registered on 2/13/2003
Posted:2/13/2003 16:01
Just wondering if anyone has had trouble with a tinny noise at about 1300 RPM's? I was told it could be the heat shields but found nothing lose. I also was told it could be the inspection plate on the front of the tranny. Any help would be appriciated.
Posted:2/13/2003 16:37
How did you inspect the heat shields?
Mine did the exact same thing. I actually could only pull one corner of the heat shield. That corner was the culprit. Wouldn't have found if I didn't pull on it.
A hose clamp "fixed" it.
00Limited
• Buhler, KS, USA
• Registered on 1/20/2003
• 41 posts
Posted:2/14/2003 21:11
Yea, I have the same noise. Really haven't looked in to it though. Monsta, what heat shields are you talkin about? Exhaust? I thought I read something about this on the FordExcursions.com but I can not find it. Sorry I am not much help. Hang in there maybe someone else will chime in and tell us how to fix it. Oh, and welcome to the club-neighbor.
Posted:2/15/2003 08:32
The shield is one of the many exhaust shields.
The offending shield on mine was on the Y-pipe coming from the driver's side bank of cylinders. This particular one is welded at 4 different places. The weld facing the front of the truck was broken, all the others were fine.
I would suggest that maybe you could crawl under and have someone you trust A LOT rev the engine to 1300 and see if you can locate it that way.
Beerman, it [i]does[/i] do it when in PARK too right? You know...with no load on the engine?
Ken
Beer Man
• Newton, KS, USA
Posted:2/15/2003 10:42
Yea, it still does it when in park. I would love to fix this as it is a pet pieve of mine to have little noises like that.
I'll give your idea a try Monsta and see how it works out.
