Headlights and fog lights
Thread Statistics:     Users to Post: 8   |   Total Posts: 22   |   Total Views: 2331
Bryan Strietzel
• Bryan, TX, USA
• Registered on 10/2/2003
• 14 posts
Posted:1/10/2004 07:08
I am looking at Hoen replacment bulbs. I used these in Germany and loved them. They are the closest bulbs you can get to Xeon HIDs. Does anyone know what type bulbs we have in the X. I think the headlamps are 9007 but I don't know about the Fog lamps. Thanks,
Bryan S
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:1/10/2004 15:24
Yes, the headlamps are 9007, but I can't say what the fogs are because I don't have any.
Rick
2004 VW Jetta TDI
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:1/10/2004 16:01
Fogs are 9005
Kevin Curry
[email protected]
http://www.texas4x4.com
Posted:1/23/2004 05:39
Bryan -
do some research about a wiring harness replacement that ties to your atteres and gives much more current to your lights...
suvlights.com among others...
watchintv
• Saddle River, NJ, USA
• Registered on 5/6/2003
• 72 posts
Posted:1/23/2004 08:57
I've read some posts that some of these after market super white bulbs and what not last around a year. Are they really worth it if you have to replace them every year?
Posted:1/23/2004 14:24
I have heard that too,
but mine have lasted longer than that..
it may be an installation problem... someone touches the bulbs and pow they pop ater a bit!
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:1/23/2004 20:29
Has anyone added fogs to their X? I just bought a pair of used SD fogs to be installed on the X. I also plan to add the suvlights wiring harness for the headlights. I popped the hood and there doesn't seem to be much room for two sets of relays. Where did you mount yours?
//bruce
edited 1/23/2004 20:30
MONGO
• Sandwich, IL, USA
• Registered on 1/3/2003
• 210 posts
Posted:1/23/2004 22:14
Got a set off of Ebay and made made my own harness. Their easy to mount. Take the front bumper off, it`s just 6 bolts and have a buddy help you so you don`t drop it or scratch the truck. They mount on the back of the bumper. While your at it drop in a set of 9005 SilverStars. As for mounting the relays, I got 5 or 6 mounted on the pass. side behind the radiator support in front of the batt.
MONGO
• Sandwich, IL, USA
• 210 posts
Posted:1/23/2004 22:33
http://www.superford.org/registry/vehicles/showmedia.php?id=73581
This is an old pic. but if you look down at the right hand corner you can see 3 mounted.
Gen-X
• Toronto, XX, Canada
• Registered on 1/19/2004
• 344 posts
Posted:1/26/2004 08:32
Guys, just a quick question regarding replacing the factory fogs bulbs with SilverStar 9005ST.
When I researched for a replacement bulb at http://www.sylvania.com/auto/silverstar.htm it suggests a 9145 45W bulb. This would run at 90W total or 7.5 amps at 12V. Using the 9005ST which is the same size bulb would ran at 130W or 10.8A at 12V.
My question is my 2003 X only has a 10A fuse for the fog lights. Now, I agree with MONGO, the factory harness should handle is but how are you guys getting around the fuse problem? Did you replace the fuse with a 12A or 15A? Maybe Ford reduced the current capabilites of the 2003 model year.
Sorry to pick on this point. It's the Engineer in me
Cheers
