Towing with my X
Thread Statistics:     Users to Post: 10   |   Total Posts: 12   |   Total Views: 3517
roger warden
• bethalto, IL, USA
• Registered on 11/13/2004
• 26 posts
Posted:12/28/2004 22:51
I have towed 7000 pounds with my 2000 X for 4 years-- in Overdrive. Transmission is fine. Just changed my stock brake pads and rotors at 65000 miles.
dddenio
• Detroit Lakes, MN, USA
• Registered on 8/18/2004
• 41 posts
Posted:2/1/2005 16:11
Third, never, ever, ever, ever tow in overdrive.
I am not a transmission shop customer.
Towing in OD is okay. The TC is locked.
Excessive shifting [u]should be avoided[/u] (eg. in hilly terrain) by simply locking it out.
You can tow in OD as long as trans isn't hunting for gears "excessive shifting". You can install a manual torque converter lock up switch and keep it locked. Here's the instructions for making this modification, http://www.forgotton.net/mods/tclock/index.htm .
Heat kills Transmissions Period! Get a trans temp guage too!
Dennis
Towing with my X
