Tire Questions
Thread Statistics:     Users to Post: 9   |   Total Posts: 18   |   Total Views: 2037
Marshall Multhauf
• Eau Claire, WI, USA
• Registered on 2/29/2004
Posted:3/2/2004 02:36
I am considering Firestone Destinations m-t 285/75/16 tires for my 2000 Limited. These are "mudder tires" has anyone heard anything about them? I like there looks but I also tow a 33' camper and believe they will still be o.k.
edited 3/2/2004 02:41
Posted:3/7/2004 00:46
R they load range E like my BFG Rugged Trail that came stock on my 4x4
Gen-X
• Toronto, XX, Canada
• Registered on 1/19/2004
• 344 posts
Posted:3/7/2004 18:57
Hey Marshall,
Johnboy is right they need to be load range E. The Firstone Destinations only come in LT23585R16 and LT24575R16 for that range. The 235s would work OK but there a really narrow looking tire.
I would look at the following:
BFgoodrick Rugger Trail (stock on 2003 X)
http://www.bfgoodrichtires.com/bfgapp/catalog/tires/ruggedtrailta.jsp
Or
NittoTerra Grappler
http://www.nittotire.com/tires_terragrappler.asp
Cheers
edited 3/7/2004 18:58
Gen-X
• 344 posts
Posted:3/7/2004 19:21
If you want to see what 235 85R16 look like on the X take a look at the "POWERBUS" in my photo album under my name GEN-X.
I use these tires for winter.
Marshall Multhauf
Posted:3/7/2004 22:42
The Destinations are load range D, same as stock tires, I'm a little new at the load range thing, will this not work for what I have to tow. I previously towed my 33' camper with a 97 Ford Expedition?
edited 3/7/2004 22:42
Gen-X
• 344 posts
Posted:3/8/2004 16:59
Having the load range D was the problem with the old tires. The Excursion by itself requires the load range E which means 10 ply tires, D are only 8ply.
The load range is explained better at the below link:
http://www.dualport.com/bustech/load_tires.html
Pulling a trailer only adds more weight on to the tires! Keep in mind the X is 2000lbs or (1ton) heavier than the Expedition. You need E range! don't get anything else unless FORD will stand behind it!
edited 3/8/2004 17:02
Larry Thompson
• Columbus, OH, USA
• Registered on 2/2/2004
• 22 posts
Posted:3/12/2004 20:29
Check out the Bridgestone Dueler Revo. I just had these installed on my X. Read all of the good comments on the Tire Rack site. My Firestone dealer put these on for me for the recall.
2000 Excursion V-10 4X4
Posted:3/13/2004 04:07
That's a bit of a generalization. All D load rated tires do not carry the same weight. Plus, they are not [i]truly[/i] 8 ply (or E's 10 ply). If I remember correctly there only actually 4 plys. The old "ply" rating had to do with older cotton ply tires. It is an old rating system that has (is slowly in the public's mind) been replaced with the letter designation.
Look at the side wall of the prospective tire purchase. Make sure that they can safely carry the GCWR at a NON-max pressure. And that the Max pressure load capacity exceeds the GCWR by a safe margin...say 10-15%.
A Firestone A/T D rated tire can support over 3000lbs per tire at MAX pressure. That greatly exceeds the "load at ground" capacity of the Sterling rear axle.
Problem was the tire pressure prescribed (too low) and the shitty construction of the tires. Not the load rating being D.
edited 3/13/2004 04:10
Gen-X
• 344 posts
Posted:3/14/2004 21:23
Ken,
I stand corrected, I didn't realize load range D would support that much weight.
Thanks for setting my straight.
Cheers
edited 3/14/2004 21:25
CoolStrategist
• Registered on 1/11/2005
• 79 posts
Posted:3/15/2005 14:46
Ok...I just left Firestone and the manager told me they are clearing out the Dueler AT6793 II for $110 per tire ($579.00 for 4 installed). This is a "D" rated 285/75/16 tire. I have read the comments posted above. I drive on the road only 60% city and 40% highway.
For the next year I will not tow anything other than my wife, 1 year old twins, 12 year old daughter and her friends. I currently have the Steeltex "E" rated 265/75/16 tire. My primary concern is quiet ride and rain and snow traction.
First...do I want this the AT693 II tires? Is this a good deal? What happens when I move up to 285s?
Or should I buy the newest Dueler AT Revo at $876.00 installed.
Or just stick with my Steeltex?
Any opinions are greatly appreciated. I am limited on my tire knowledge.
Black 2003 4x4 Limited V10; 285/75 BFG Dueler Revos; Viper 791xv Remote Start and Alarm with voice module; Hellwig Rear Sway Bar; Go Industries Rancher Grill Guard; Limo Tint; Rancho RS9000X Shocks; Line Of Fire LED Lights; WeatherTech Dark Window Deflectors; 2005 Heated, Signal, Running light TTT mirrors; PIAA 550 Driving/Fog Lights; PIAA 9007 Headlights w/upgraded wiring harness (bright!); PIAA 9005 fogs; Optima Yellow Top battery
Tire Questions
