Door Ajar Light...
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 589
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:3/11/2004 00:05
stays on after all doors are shut, checked, double checked, etc. I believe it is the Driver's door that is having the problem, but where do I find the button or whatever to check/change??? Is there something else I should check???
Mark Rychel
• Chesterland, OH, USA
• Registered on 3/10/2003
• 54 posts
Posted:3/11/2004 07:16
I had the same problem, on my drivers door, i sprayed some wd40 in the lock mechanism on the door and moved it around a little bit with a screw driver to let the oil penetrate. Did the trick for me.
Mark
Posted:3/11/2004 16:25
No Pin-switch like the old switches mounted in door jambs. Your switches are attached directly to the latch mechanism inside the door.
Wheels
• Visalia, CA, USA
• 214 posts
Posted:3/12/2004 12:22
Mark
Did just that this morning, and..........problem fixed!!!!!! Thanks.
Ray Eskridge
• Chicago, IL, USA
• Registered on 3/7/2004
• 14 posts
Posted:3/12/2004 15:58
I had the same problem on my 2002 Excursion. Took it to Ford, the checked and lubed everything, problem fixed.
Ray
Door Ajar Light...
