Sporadic Idle
Thread Statistics:     Users to Post: 4   |   Total Posts: 9   |   Total Views: 678
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:3/29/2004 14:47
It seems like my wifes Ex is idleing strange. Kind of up and down, up and down....It has 105K on the clock, it is a 2000 limited V-10. Any ideas where to start looking?????
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:3/29/2004 21:43
Fuel filter?
Rick
2004 VW Jetta TDI
Posted:3/29/2004 21:46
IAC could be the culprit.
there is a picture of it here
How much variation in the RPM is there at idle?
edited 3/29/2004 21:47
RS-TX
• 298 posts
Posted:3/30/2004 07:24
I thought of the IAC, but when mine went bad it didn't have a variation in idle, it just died
Of course, that could be considered a variation I suppose.
Rick
2004 VW Jetta TDI
Wheels
• Visalia, CA, USA
• 214 posts
Posted:3/31/2004 14:39
How often should I replace the fuel filter??? Did it about 10k-15k ago....
I will change it this weekend, better safe than sorry.
I will check the IAC, the page mentioned said something about cleaning....is it worth trying?? How would it be cleaned?? How much is a new one?? Can you get them on ly at ford dealership??
Thanks for the help...
RS-TX
• 298 posts
Posted:3/31/2004 21:34
I don't know. Just a thought.
I didn't even try cleaning mine. My dealer charged $144 to install a new one.
Rick
2004 VW Jetta TDI
Wheels
• Visalia, CA, USA
• 214 posts
Posted:4/26/2004 11:18
OK, money is about to come in to have the IAC fixed... but would this make it idle FAST....like 1500 RPM, and keep it there?? After truck is already warm?? Cruising around looking at houses it wanted to run, Then I was able to "Get on It" on the freeway, and then after it came back down to normal idle.
RS-TX
• 298 posts
Posted:4/26/2004 13:03
No, when my IAC went bad my X did not want to idle at all, but rather tried to die if I didn't keep the rpms up. Sounds like you may have a different problem. Good luck with your X.
Rick
2004 VW Jetta TDI
bjeepin2
• Slidell, LA, USA
• Registered on 5/7/2004
• 9 posts
Posted:5/7/2004 10:10
have your O2 checked
Sporadic Idle
