Excursion squeeling
Thread Statistics:     Users to Post: 8   |   Total Posts: 14   |   Total Views: 1526
Posted:4/17/2004 05:14
Whoa...we're gettiong waaaaay out there on possible problems!
Since you just did the front brakes, I would suspect that is where the problem lies. When I installed my ARTS they squealed just as you describe. Only did it when I turned and applied the brake. I checked and rechecked everything before I put it back together!!! Or so I thought...
Well, I checked it again and found one of the metal backing tabs was bent a bit too far. It was in there kinda loose. When I would turn and apply the brake, there was just enough "slack" to cause it to rub against the rotor.
I pulled the pads and bent the tab with pliers to ensure that it had a good grip against the pad and the noise went away.
Jay Wehrle
• Fort Wayne, IN, USA
• Registered on 4/15/2004
Posted:4/18/2004 16:46
I pulled the rear wheels and the back brakes looked pretty good except for a slight ridge around the outside and inside edge where the pads had worn the rotor. I put new rotors and pads on anyway and all my woes are solved. Stops straight and the harmonic squeal is gone. Thanks for the help and drive safe.
Jay
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:4/19/2004 15:42
I had a "groan" out of the rears particularily when Iwas backing up and putting on the brakes.
Seems to be somthing inhearant about the rears.
Dave S.
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:4/20/2004 22:07
I'm tellin ya, its the squirrels!
Rick
2004 VW Jetta TDI
Excursion squeeling
