Tranny cooler
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 609
sfd4
• Linden, NJ, USA
• Registered on 4/14/2004
• 31 posts
Posted:4/22/2004 20:39
My Excursion is a 2000 Limited with V10/ 3/73 rear and supposedly the tow package. Ford cannot tell me if it has a trans cooler or not. It was delivered in Feb 2000. In frront of radiator there is a small black type cooler. However in tracing the lines they go to some type canister on drivers side. Anyone have ideas? I am also trying to get a service record and a build record for my vehicle which I just bought with 17,500 original miles
2000 Excursion V10 Limited. White/Tan
2004 Fleetwood 34ft Travel Trailer
sfd4
• Linden, NJ, USA
• 31 posts
Posted:4/25/2004 10:56
So no one knows if they have a transmission cooler on their Excursion?
Doug Loper
• Byron Center, MI, USA
• Registered on 9/26/2003
• 114 posts
Posted:4/25/2004 16:47
I checked the manual and also checked my X. Mine is 2000 with V-10 and 3.73. It has a tranny cooler which is located between the rad. and a/c cond. You can see it if you look down through the hood latch opening, it is is the bottom half of the gap. Service record should be obtainable through dealer, though it may not be complete, if work has been performed by an individual not in the network. Good Luck.
2000 X V-10
Mods: 6" Revtek lift
35" M/T Baja Claw Radials
16" x 10" Eagle Alloy Rims
SilverStar 9007
Clear front corners.
Posted:4/26/2004 04:35
The little cooler you see is the power steering fluid cooler.
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:4/26/2004 16:44
the first models built in 99 were NOT installed with a cooler but there was a tsb on this. All since were built with a cooler. I have just bought a aux one to run with the factory one. A little extra cooling.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Tranny cooler
