Tow Mirros and Break Controllers
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 515
tubaman
• NW Burbs of Chicago, IL, USA
• Registered on 4/23/2004
Posted:5/1/2004 20:01
I just purchased a new 2004 Excursion limited. Unfortunatly it had the regular mirrors instead of the tow mirrors. I found that I can order them from Form for around $300.00 My local dealer wants another $200 to install. Is this something I can do myself? Has anyone tried this before?
Also I need to add a Break Controller. From what I read I am going to get a prodigy. Since the wiring is already there am I right in assuming all I have to do is mount the controller and using the Ford wiring harness plug the controller into the plug provided?
Thanks for all your help
David
[email protected]
Posted:5/2/2004 10:41
First, welcome to the forum. You'll find a lot of good info here. And along that line, the tow mirrors (AK T-T or moose-ear mirrors) will replace your dog-ear/paddle mirrors with minimal problems (mostly related to wiring connectors). That subject has been addressed a few times, and I suggest you scroll through the pages to find more relevant info. The Prodigy is a great brake controller (I'm running one), but you will need to buy an adapter harness ... one end gets hard-wired to the Prodigy unit, and the other plugs into the Excursion wiring harness. Again, the particulars have been discussed at great length on some other post(s) here at SuperFord. I don't mean for my comments to sound like I'm "brushing you off" ... but the info you can find here is much more detailed than what I can type within the next hour or two.
edited 5/2/2004 10:42
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:5/2/2004 17:43
I too have a Prodigy and love it!!! As Landyot said get a typical Ford harness and wire the brake controller to the pig tail then plug it in. The mirrors are a direct plug and play. Buy the mirrors then remove the door's2 screws and lift the door straight up. 4 bolts and un-clipping the plug and the reversing the same for the install...Good Luck...It's Easy!
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
