Height with v-codes?
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 545
Fixxxer
• Minot AFB, ND, USA
• Registered on 5/20/2004
Posted:6/4/2004 19:45
Hi all, first time poster, (been lurking for a while though). Love the forum, what a great source of info. What I need to know is if I change to v code springs, how much will the front end raise('01 Limited 4x4)? I've read many posts, with some conflicting opinions...
Supposedly the x codes will give you approx 2.5", but will the v's give around 2" or so?? Buying used v-codes is a lot cheaper than buying a hanger kit I'd rather buy shocks with that money.
Thanks for any info
Fixxxer
Edit: Doh, forgot to say it's a V10...
edited 6/4/2004 19:57
Lou Beckler
• Wakeman, OH, USA
• Registered on 4/27/2003
• 43 posts
Posted:6/5/2004 06:13
Spring info
Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
------------------------------------/spring---to Max Cap ----height ----height
---------------------------------------------------------------- change --- change
Exc V8 -------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 ----- -0.66
Exc V10 ------ C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 ----- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ------ 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependant
Application---Code---Capacity-----Rate----Travel ------------- V-10 ----- PSD
--------------------------------------- /spring---to Max Cap ----height ----height
------------------------------------------------------------------ change --- change
SD-250/350
------------------ S --------4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
------------------ T --------4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
------------------ U --------4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
------------------ V --------5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 ----------- W --------5600 ----- 450 ------ 5.34 --------- +2.77 --- +2.52
F550 & 350/ DRW with Snow Plow prep Package
----------------- X-------- 6000 ----- 470 ------ 5.54 ---------- +2.90 --- +2.68
Fixxxer
Posted:6/5/2004 13:44
Sweet, thanks for the info. I had seen this once but couldn't find it again. Looks like the v codes will get me just under 2"
