Problems with EGRBrakes Stainless Steel Brake Lines-DON
Thread Statistics:     Users to Post: 1   |   Total Posts: 1   |   Total Views: 624
Richard Smith
• Knoxville, TN, USA
• Registered on 10/4/2003
• 104 posts
Posted:7/1/2004 19:15
I improved my 2003 Exc V-10 4 x 4 brakes with S/S brake lines. The EGR Lines I used function well but don't fit "worth a s---!" I can't remove the caliper without removing the brake line (bleed brakes when you change pads) and the end that attaches at the frame won't work with the factory bracket. Their original fix was for me to tie wrap the hose at the frame and wait for them to develop a line kit that would work with stock brackets and permit changing pads without removing the lines.
Guess what today, after 3 months ,the owner of the EGR Company told me they won't doing anything to resolve the problem - that I should grind off the corner of the banjo fitting so it can be turned to clear the caliper bolt and figure out something myself to secure the other end. So much for Customer Service or should I say Customer No Service.
STAY AWAY FROM THIS BUNCH!!!
Thanks, Richard from Knoxville, TN
