Air Lift for X
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 858
Jukka Heikkila
• Helsinki, XX, Finland
• Registered on 7/30/2004
• 25 posts
Posted:8/19/2004 06:11
Hello
Does anyone have any experience with Air Lift for X ?
Feel like need to install it to survive with our northern bumpy roads.
dddenio
• Detroit Lakes, MN, USA
• Registered on 8/18/2004
• 41 posts
Posted:8/19/2004 09:03
Air Lift would be adding rear Air Bags to existing leaf spring suspension. If you are a hauling load or Trailer wih a lot of tongue weight, Air Bags would help. This method generally stiffens ride.
Now an Air Suspension from KeldermanMFG would improve ride!
They have 2 options, $899 (US) replaces rear shackles with an Air Ride Mechanism or for $2600 per axle you can install a whole new 4 Link Air Ride Suspension System (Replaces all leaf springs). These are supposed to make dramatic improvements over factory.
Dennis
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:8/19/2004 10:41
Hello
I am also looking into placing some bags, maybe firestone's on the rear of the X. I have 2 xtra leafs in the rear spring pack and the rough ride is killing me and the truck. I have a freind that has them on his f-150 and with about 15lbs of air in the bags the ride is nice...not to harsh. I will look into it more and get back with my findings.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Jukka Heikkila
• 25 posts
Posted:9/22/2004 09:06
Hello again gentlemen
I finally installed the air lift kit from air lift company ( airliftcompany.com ) 394 USD the whole system with airbags between the rear leaf spring and bump stop , the compressor and monitoring system inside the cabin. I put pictures later.
The work took one full day, but the parts fit perfectly. Thanks for that Air lift co.
Good point in this system is that you can run it with normal air pressure level when you don't need it and add air when needed. I haul a dual axel trailer and this air lift system has reduced the vertical swinging caused by a big trailer and it has softened the bumps as well. So overall I'm pretty happy with it.
Like said I add the pictures later
Posted:9/22/2004 15:22
Glad to hear all went well with the air-bags. Welcome to the forum from this side of the pond!
Air Lift for X
