Which Poly Bushing Kit - Front Sway Bar?
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 815
Hooked
• Vancouver, XX, Canada
• Registered on 9/7/2004
• 13 posts
Posted:10/19/2004 01:34
Hi All,
I just got my 2000 X (4wd) back after having new Rancho shocks and a Helliwig sway bar installed. Big difference in the back end Don't know if it was the shocks or the sway bar, or both, but I'm a happy camper.
I was also going to install a set of Energy Suspension poly bushings on the front sway bar to try to tighten up the front end as well, but the shop I took it to said that the bushings I bought don't fit. I ordered according to the Energy Suspension application guide and got part # 4.5108G which is supposed to fit Ford 1 1/4" sway bars. The mechanic said that the sway bar on the X is approx. 1.40". I should mention that this was a Ford dealership where my friend is the service manager.
Soooo....can anyone tell me if I have the right part, or did I mistakenly order the wrong one? If this set really doesn't fit then I will go ahead and order the proper set. Any recommendations on brands other than Energy Suspension and/or any suggestions on where to buy then on-line?
Thanks in advance.
Brian
Hooked
• 13 posts
Posted:10/19/2004 01:50
OOOPS!
Never mind, I just realized the problem...I ordered part #4.5180G and got part #4.5108G instead. Sorry for taking up bandwidth!!
Brian
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:11/14/2011 20:29
Hi All,
I just got my 2000 X (4wd) back after having new Rancho shocks and a Helliwig sway bar installed. Big difference in the back end Don\\'t know if it was the shocks or the sway bar, or both, but I\\'m a happy camper.
I was also going to install a set of Energy Suspension poly Truck Bushing Kits on the front sway bar to try to tighten up the front end as well, but the shop I took it to said that the bushings I bought don\\'t fit. I ordered according to the Energy Suspension application guide and got part # 4.5108G which is supposed to fit Ford 1 1/4\\" sway bars. The mechanic said that the sway bar on the X is approx. 1.40\\". I should mention that this was a Ford dealership where my friend is the service manager.
Soooo....can anyone tell me if I have the right part, or did I mistakenly order the wrong one? If this set really doesn\\'t fit then I will go ahead and order the proper set. Any recommendations on brands other than Energy Suspension and/or any suggestions on where to buy then on-line?
Thanks in advance.
Brian
can you suggest me the best store to order bushing kit? any help please. thanks in advance mate.
