Trailer Brake Wiring
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 498
Bruce Coyne
• Fircrest, WA, USA
• Registered on 1/6/2003
• 12 posts
Posted:3/7/2003 19:50
Do you have a brown wire on your brake control pigtail that is not being used?
I purchased a Draw-Tight brake controller and have the factory pigtail for hookup. The Pigtail has 5 wires and the brake contoller has 4 wires. The Excursion owners manual has nothing about connecting the pigtail and the installation instructions from Draw-Tight refer me to the vehicle owners manual! Thru a search of the internet I finally came across a guide that decoded the wires(DO NOT MATCH COLORS). But one wire, the brown pigtail wire, is listed as NA. So, does that mean the brown wire is capped off?
Paul Goulet
• Easthampton, MA, USA
• Registered on 1/29/2003
• 33 posts
Posted:3/9/2003 12:52
You do not need the brown wire. It is for illumination.
Paul Goulet
Easthampton, MA
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:3/11/2003 14:09
Take a closer look at that wire, is it brown or brown and white stripe?
The excursion trailer/camper adapter is wired as follows.
pin 1 is yellow (YE) and is left turn input
pin 2 is white (WH) and is ground
pin 3 is dark blue (DB) and is electronic brake
pin 4 is dark green (DG) and is right turn input
pin 5 is orange (OG) and is battery B+ (charging ckt)
pin 6 is brown/white (BN/WH) and is B+ Park or head ( running lights)
pin 7 is Black/Light Green (BK/LG)and is Reversing lamp input (back up lights)
Hope this helps.
Dave.
edited 3/12/2003 08:32
