6 Disc Probs
Thread Statistics:     Users to Post: 3   |   Total Posts: 12   |   Total Views: 1089
Matt Cawson
• Caledonia, MI, USA
• Registered on 10/20/2004
• 82 posts
Posted:11/9/2004 15:02
Hey Guys. I pulled out the stock 6 disc changer and put in a new head unit. I went to put the old 6 disc unit into a friends truck and it comes up with "disc error"...and thinks that all slots are full. Is there some sort of tricky anti-theft dealer only knows about code or sequence that needs to be hit to get the thing back to normal? If not I'll tell him to just scrap it, but the thing worked perfectly fine before I took it out.
Posted:11/9/2004 15:17
Did it go from a 99-2004 Superduty into an alike Superduty?
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:11/9/2004 21:21
Not ot be a smart aleck but are you sure a CD is not stuck in there? I had to send mine off before with that exact error. I took it apart to retrieve my CD's first. When I looked inside the lift mechanism for the discs is connected by these puny rubber bands to drive the mechanism. I had one that had snapped. However, I still get them stuck and get that error. I took a thin flat piece of metal-thinner than a cd-wrapped with 3M double stick tape and pulled the stuck CD right out. I wish you luck and hope this helps!
Matt Cawson
• 82 posts
Posted:11/10/2004 06:34
Went from an '01 X-ltd into an 01 F250 superduty...but I had the problem even before we tried to put it in his pickup...I left 4 discs in it when I first took it out, so I had to plug it back in to get them out. That's when this all happened.
Posted:11/10/2004 08:27
That's interesting more or less So it comes up with an immediate error when you plug it in or just when you go to add a CD?
Matt Cawson
• 82 posts
Posted:11/10/2004 13:15
When I triy to add, play, or eject. All 6 circles on it have number in them, indicating that there are 6 cd's in it, but they're all out. First it says "initializing", then I get the error. If I try to load it says "slots full", try to eject it says "select slot", then you select a slot and it says "cd error".
Posted:11/10/2004 15:40
The J1 16 pin power/speaker harness "should" be the same between the two trucks,but something tells me an event of shifting or shock might have occured between the two trucks(that's just what my mind is telling me)
Possible to crack it open to see if anything's hung up or stuck somehow?
Matt Cawson
• 82 posts
Posted:11/11/2004 05:38
OH yeah...we've had that sucker completely apart and found nothing. He's just going to call a dealer tomorrow to see if there's anything that can be done. Otherwise it's headed for the boneyard!
Posted:11/11/2004 11:24
Worth getting a repair guesstimate?
David Rush
• 233 posts
Posted:11/11/2004 20:06
Matt, you can look up Visteon on the web. They make that exact after market units as factory except they have all the updates. It is likely from what I read that one of the Belts in the transport mechanism is broken. If you go through the dealer-expect 200-250 to fix. Visteon alternative is much better IF you don't have extended warranty coverage.
Found the link
http://www.visteon.com/technology/automotive/cd6_music.shtml
see if that looks a little familiar.
6 Disc Probs
