Loose doors.
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 518
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:11/16/2004 21:42
Ive got a problem thats been buggin the heck outta me for a month or so....my 2nd doors on both sides rattle, and seem like they are loose. Is this normal or can I adjust the keeper for the door inboard so that they are engaged tighter?? It drives me nuts goin down the road over uneven stuff they sound like the latches are loose!!
Thank you!!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Posted:11/16/2004 22:13
Scott....
you just hit on my only complaibnt about my otherwise superb X....
the drivers side rear dorr would "rattle" at times...
dealer was very cooperative and adjusted it for me....
now I have wind noise and can HEAR the road noise....
Am going to bring it to a buddy of mines auto body shop - figure they can
"beat it to fit and paint it to match" !!!!!
Posted:11/17/2004 10:18
Once they've adjusted the doors that puts the weatherstripping out of place so to speak. Might have to put a new set on to get the door and body to seat up again for a good seal.
Maybe put a thin bead of petroleum jelly on the weatherstripping going around the doors close then open to see what part/s is not making contact.
Just a suggestion
Scott Stover
• 354 posts
Posted:11/17/2004 17:49
Thank you very much guys....I just wanted to make sure I wasnt the only one out there with this problem!! I will work on it this weekend!! I will post the results
Bill, John, thanks again!!!
K&N
Gibson Catback
"Custom" Kickplates
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:11/18/2004 21:56
I had a lot of play in my left rear door ie you could push in and really feel it spring against the weatherstripping. Body shop had to drill out latch bracket and replace it after adjusting position. It helped but I have had to add weatherstripping "wedges" in critical areas to dampen vibrations. I noticed both rear doors to not have rubber bumpers just below window level where there is clearly a site for that. I placed weatherstripping there. I also placed formed weatherstripping between the latch bracket and the body so that that area of the door has plenty of dampening. I akso lined all my doors with hush mat as I was upgrading speakers. It definitely helped a bit along with vaseline on all bumpers to reduce squeaks. GOOD LUCK!
Scott Stover
• 354 posts
Posted:11/19/2004 17:29
Thanks Dave!! I appriciate it!
K&N
Gibson Catback
"Custom" Kickplates
Loose doors.
