Part numbers for greaseable ball joint installation?
Thread Statistics:     Users to Post: 5   |   Total Posts: 13   |   Total Views: 7132
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:1/4/2005 05:35
Eric, I had to replace my ball joints at 70k miles. Actually, the drivers side were bad and I chose to replace both sides. My mechanic (used to be a team lead at the local Ford shop) checked on OEM joints but non were greasable. So I went with NAPA. Even with the risk of dirt and moisture, I felt that the greasables had to give me better life than 70K.
//bruce
Richard Smith
• Knoxville, TN, USA
• Registered on 10/4/2003
• 104 posts
Posted:2/4/2005 06:59
Here's what I do and have done for a long time. I get a Hypodermic Type Grease Injector from Advance Auto or equal and grease all those sealed ball joints. I have never had to replace a ball joint or tie rod end (in 50 years of driving) that I have greased on a regular basis. Grease-in keeps dirt and water-out! Sometimes you can drill and tap a hole in the sealed ball joint and screw in a Zerk -just be careful to pick out the chips.
From a long time Ford Fan and retired Ford PowerTrain Engineer in Tennessee!!!!
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:2/4/2005 18:05
Thanks for that tip Richard
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
