Rear Limo Tint--PIAA Backup Lights Worth it??
Thread Statistics:     Users to Post: 8   |   Total Posts: 19   |   Total Views: 4525
CoolStrategist
• Registered on 1/11/2005
• 79 posts
Posted:2/11/2005 08:55
Thanks! I will let you know how it goes.
Black 2003 4x4 Limited V10; 285/75 BFG Dueler Revos; Viper 791xv Remote Start and Alarm with voice module; Hellwig Rear Sway Bar; Go Industries Rancher Grill Guard; Limo Tint; Rancho RS9000X Shocks; Line Of Fire LED Lights; WeatherTech Dark Window Deflectors; 2005 Heated, Signal, Running light TTT mirrors; PIAA 550 Driving/Fog Lights; PIAA 9007 Headlights w/upgraded wiring harness (bright!); PIAA 9005 fogs; Optima Yellow Top battery
Posted:2/11/2005 09:04
ok CHP....
WAY brighter than mine...
Which wire did u connect them to ?
did u run all the way up to the battery for power and use a backup lamp as the switch trigger ?
or just splice into the backup lamp ?
I got the wiring from another Powerstroke owner to where he tied into the power from the reverse light circuit off the tranny and constant hot off the battery.
Using a single throw/double pole switch it'll operate in 3 ways;
1-Factory reverse lights on
2-Factory reverse lights on plus Auxiliary lights on
3-All Lights off
I forget which Auxiliary light package you have on your Excursion there John?
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:2/13/2005 07:15
I put a relay in the back and used the battery on the 7 pin trailer plug.
I taped the reverse wire to one termial,ground to another,battery to another,and final output to the last termial on the relay. I wish i knew how to draw up a diagram on the pc gizmo
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Posted:2/13/2005 08:54
Could also draw it up on a piece of paper,take a couple photos of it then upload it to your photo album
corloske
• wichita, KS, USA
• Registered on 2/19/2004
Posted:2/13/2005 09:05
Have any of you guys thought about taking one from the RV owners and use a rear camera and moniter set-up. I saw a license plate frame with a camera. it was under 200.
Posted:2/13/2005 19:59
This is scary Scott...
but even "lectrical" challenged me understood it !!!
And just found my pigtail from the Ex's glove box with a wiring diagram of which is pin 7 !!!!
Now I need to go to Radio shack to get a relay....
ANY relay ?
Thanks a million !
Matt Morris
• Trevose, PA, USA
• Registered on 1/13/2005
• 9 posts
Posted:2/14/2005 14:29
I to have been looking into doing this.
PIAA makes a 1500 set of back up lights that look nice. They also now have a very compact rear foglight that uses LEDS. I am going to look into those as they contain as many as 10 LEDs, but since they are LEDs, you could probably just jump from the back-up light wiring...maybe even from the trailer plug. LEDs use very little power.
I just have to make sure that they would be bright enough. If memory serves me the PIAA # is19154.
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:1/17/2012 16:10
ok CHP....
Using a single throw/double pole switch it\\'ll operate in 3 ways;
3-All Lights off
I forget which Auxiliary lights package you have on your Excursion there John?
i just wanna ask if where to buy an auxiliary lights? any response is highly appreciated.
smithalice
• uk, KS, USA
• Registered on 4/24/2013
Posted:4/30/2013 00:38
ok CHP....
inquiring minds wanna know so I can SEE too !!!!
We are located in Atlanta and offer fleets of luxury vans, SUVs, limo vans, charter buses and many more to offer you awesome ground transportation. offers stress-free transportation experience to our customers.
