F-350 springs installed on an Excursion?
Thread Statistics:     Users to Post: 4   |   Total Posts: 8   |   Total Views: 1631
Jay Hanratty
• Millbury, MA, USA
• Registered on 8/13/2004
• 35 posts
Posted:5/1/2005 08:17
Hi
I currently have a 20017.3l PSD 4x4 Ecursion, I tow a 37' 12,000lb travel trailer and I have severe squat in the rear of my Ex .
When I first got the Ex I had a local spring shop install a set of underspring helpers and a set of Timbrens and added a leaf to the front. I'm finding that the rear springs still are on the weak side, I have a difficult time equalizing my hitch. Has anyone installed a set of f-350 springs? if so do you have the part numbers, and how many leafs are there?
Jay
aka Nascar24
Posted:5/1/2005 21:58
The squatting effect of the rear springs I'm not keen with either when we tow
What I know about the SuperDuty rear springs is that they are a straight swap with the Excursion springs.
The stock Excursion springs have a capacity of 5,200 lbs,the Superduty springs on the F250 are 6,000 lbs(A code) and the F350's are 6,800 lbs(B code)
I'm hoping to pick up a set of A codes on our return trip from California early next month to replace our broke in stock springs/F350 blocks with the correct spring code
Jay Hanratty
• Millbury, MA, USA
• 35 posts
Posted:5/2/2005 05:42
Hi
Thanks for the info, you mentioned something about blocks,, do these also need to be changed?
EXCAV8TER
• AUSTIN, TX, USA
• Registered on 4/2/2005
• 19 posts
Posted:5/2/2005 20:06
This would explain why my F350 barely squats when I load my 25' tandem dual with a 310 4X4 backhoe!
Tom
http://community.webshots.com/album/73765967gytwCm
2000 4X4 Limited PSD Excursion, Toreador red and tan, Edge Evo, AFE, Eddins house of Diesel 4" Exhaust, Rancho RSX's, Hellwig anti-sway. 10" DVD player coming soon.
1999 F350 CC DRW, Tourmaline Blue, AFE, Suncoast with triple lock,ART Rotors,Magnaflow Stainless with polished 18" tip,PS2000 LP kit, Diesel Innovations Custom 4 POS chip.Lunar Gaugesin 3 pod pillar, 12 Speaker 770watt sound system with Sony, Infinity, and Fozgate components, XM, Acetoned badges14.80 @ 94MPH...hot rod towing machine! Soon to have 6.0 Variable vane turbo!
Our rigs http://community.webshots.com/album/73765967gytwCm
Posted:5/3/2005 08:59
Hi
Jay I installed the F350 blocks due to the stock rear springs had "relaxed" in abit faster than anticipated and want to avoid the nose up posture when in tow as that can wreak havoc on a front end
absolutezero273c
• Toledo, OH, USA
• Registered on 4/9/2004
• 81 posts
Posted:5/3/2005 18:15
My X squats with the new camper I got this spring. Too much for my comfort zone.
I was thinking about air springs like thishttp://www.drivetrain.com/superduty.html.
2001 Flagstaff 829-BHS
Posted:5/3/2005 18:38
Those or Firestone Ride-Rites will work well
Jay Hanratty
• Millbury, MA, USA
• 35 posts
Posted:5/21/2005 21:32
Hi
Just an update
I had a set of 3000lb rear springs for a F-350 SW installed I thought the 4400lb set would really be too hard.
The spring shop had to re-arch the new spring,, raised the rear by almost 3" way too much. They left my under helpers in place and replace the bottom under helper leaf old one was way too weak and not doing much.
With the new springs in the truck sits perfect, when I hook my trailer up it drops about 1/2", I have to re-adjust spring bars on hitch and all should be good, thats tomorrows project.
Cost me a little over $500 and worth every penny!
